Hi, my name is Chris and I’m new to watch repair. Always found it fascinating so thought I’d give it a try so bought some cheap vintage automatics watches and giving it a go.
I do have a specific question. I bought an old orient watch with a 46940 movement. I’ve taken it apart and put it back together, minus the balance wheel which I wrecked but not sure it was working to begin with, but the time, date and day all move so good sign. The crystal was damaged and when I tried to take it out I broke it. Now I’m struggling to figure out the crystal I need for it. The case number is g469633-70. Anyone know the right one to get or point me to where I might get the info? From what I can find it’s a compression type.
Welcome to the forum.
Photo always help when asking questions along with your location
so we can point you in the right direction regarding suppliers.
Is it a Crystal or an Acrylic that was previously fitted and what's left to take measurements from?
I’m in Ireland. Unfortunately my wife threw out what was left. I think it was probably acrylic as seemed quite plastic. I also hadn’t realised there was a bezel keeping it in place when I forced it off and some was left in there but I’ve since removed the bezel and removed was was left. It was domed and the bezel is loose if I put in on without the lens, if that helps. I’m in the office at the moment but can take a pic later. Is there anywhere that has any archive of specs on cases?
Not for Orient that I'm aware of.
If you've not got anything left then it will be down to measuring with calipers
and even then probably having to buy several options to cover yourself.
My first thoughts were that it would be a Tension Ring but
from your description it could be something more special.
https://www.cousinsuk.com/category/acrylic-tension-ring-armoured
Edit
This is the other type I thought it could be from your description.
https://www.cousinsuk.com/product/special-form-underlayed-sternkreuz-u
Edited by AndyGSi
Just now, AndyGSi said:
You mean an underlay like this?
Yes, seen them called a shoulder or step but not underlay.  One of the problems with terminology.
Correction, step and underlay seem to be different things.
If I understand correctly, fitting crystals to these is a challenge in my experience.  You need to find a crystal that fits the outside diameter of the case (the lip), but is not to thick for the bezel to fit over the crystal and snap in place.  Thus, there are two critical dimensions: inside diameter and outside diameter.  Most generic crystals are fitted based on outside diameter.  That's my take anyway.
Best case scenario is that you can find a genuine crystal for that case.
Thanks all for the feedback. I don’t have a Calipers at the moment but have one ordered so can’t measure yet. Will see what I can find then. Gonna look more into seiko watches going forward as there seems to be a lot more cheap ones and a lot easier to find parts.
Hi I have a new question I’m hoping someone with experience can help with. I bought a secondhand Seiko 7002-7000 dive watch and the part under the bezel where the bearing goes seems to be clogged with dirt. Any tips on how to remove, I have tried 20mins in a ultrasonic cleaner and also soaking in iso but just can’t seem to get it out
Ya was planning on replacing the spring and bearing and housing part if needed but any suggestions on how to get it out? The case is in great condition other then this so really would like to use it.
No there is no movement, if it is the bearing that’s split then it’s compacted with what I think is dirt. Bought it on eBay so could be anything
Last year I worked on a Seiko 6105-8110 that used as its bezel click a spring-loaded ball peened into the case. The ball would not move at all. I eventually got it out by working my smallest screwdriver round and round the ball to open up the part of the case that had been peened to hold the ball in. Eventually the ball came out, revealing a spring that had turned to rust. With much patience and repeated visits to the ultrasonic I got the rusted spring out. The top half of the spring had essentially disintegrated although the bottom half was largely unaffected. Once I had all the pieces of spring out and the hole cleaned up I was able to replace spring and ball.
If that is a split, try and hand wind a drill bit into it and see if you can pull it out with the complete sleeve.
I think before you go any further you need to determine or research what design it is.  Is there any sign of it on the backside ? If not then probably a spring loaded ball catch with a peened over lip to hold it in place, like the one Glen was working on last year.
Ya it doesn’t go through and I’ve seen online you can buy replacement spring, housing and bearing so that’s what I’ve assumed it is. I’ve tried a pair of tweezers and screwdriver but don’t have a drill bit small enough but I’ll get one and give that a go. Thanks for all the advice
Decided to just buy a used mid case since I have everything else I need. One thing I’ve been really struggling with though is the balances. Seems like most vintage watches I’ve bought they do move but not for long. I’ve tried to fix them but it’s not an easy job, I’d imagine it can take al long time to get good at it but any tips on what to get to try fix them? Wrecked a few already trying to correct the alignment
Balance issues and the related escapement problems can be many. It's an area of watch repair that is the least understood, so you're not alone. There are many books written about just the escapement. Thing is you are trying to repair watches that are old , worn and probably had many hands working on them , many unexperienced and untrained hands. The situation of - buy an old watch, try to fix it, cant fix it, break it a little bit more, move it along  - . A watch that you are working on might have had this happen to it a lot of times. I enjoy that challenging side of repair, but not everyone does, you try you fail, but you try again and eventually you land a success.  That success rate grows until it outweighs the fails, you just have to keep going and if you enjoy that journey of learning then the fails really do not matter. If it was easy then it wouldn't be worth doing because you wouldn't be learning anything. Consider the proverb of " The idle mind "... some say watchmaking is for the insane...pah that's rubbish, working in my watchroom is where my sanity returns......did I just make the suggestion that I could be a sane person ?🤪
22 minutes ago, AndyGSi said:
Not sure what you mean by a mid case?
It’s a term I have read in books Andy, midcase as it sits between the other 2 parts of the case, bezel and caseback.
Tom
    • Excellent info, thank you! So when you say "conforms to the standard" does that mean, for example, that parts are interchangeable between brands and ages, or that you could use accessories built for that 110-year old one on a newer one that was built in the 1990s? Also, thank you for taking the time to answer my questions and your patience.
    • It was first a brand, but became a standardized style. So you will find some older lathes actually marked "Webster Whitcomb" and many other makers who built WW lathes conforming to the same dimensions for spindle height, bed shape, attachment setup, collet size and design. https://www.lathes.co.uk/derbyshire/ So when someone mentions a WW lathe today, they are talking about any lathe that conforms to the standard, which could be a 110 year old American made lathe or a European made lathe from the 1960s or something else.
    • Hi guys, just a little thank you for the CLOCKBARN site in America.  I purchased a TIMETRAX APMLIFIER to help with setting clocks in beat from CLOCKBARN it arrived on time and when tested worked ok.  A week later I had occasion to need it again, this time nothing the unit was dead. Checked out batteries , probes etc , nothing.    I messaged CLOCKBARN  to this effect.  I got a prompt reply that he would send a replacement which duly arrived today and having tested it it’s ok.  So I can recommend the site should you need to use it. The person,persons who run it are genuine guys.  So thank you CLOCKBARN  for your excellent service.
    • Hi there! You have learned how professional watchmakers feel about Timex. It is very difficult to find one willing to work on them, for a few reasons: 1) a lot of them wrongly believe Timex cannot be serviced, are riveted together. This is a myth. 2) when serviced, they still cannot meet the performance standards of jeweled mechanical watches (-20sec/day is good enough for a Timex) 3) customers are unwilling to pay the watchmaker's hourly bench rates because the watches are worth very little The service manual for the M33 is available at https://heritage1854.com/m33 but you also need the M32 and M31 manuals because they build on each other (31 is the base, 32 has date, 33 has day and date) https://heritage1854.com/m31 https://heritage1854.com/m32 A stuck date changeover can be due to a missing, bent or broken detent spring (part 2576 in the manual) or the date wheel (2556) got stuck or separated from its post, or maybe disengaged from the hour wheel. With a little confidence, these are not difficult to repair and parts are pretty much interchangeable with any other Timex from the same era having the same features. So it is very easy to find inexpensive spares in the form of junk watches (don't bother trying to search for individual spare parts). My recommendation would be to find a junk Timex with an M25 (older manual wind with date) and practice a little with it. Follow the service manual from the same website. The automatics are a bit more difficult to work on but once you get a feel for how they fit together, you can make an attempt at your automatic and you would be able to use many spare parts from the M25 if necessary. To work with most Timex movements, you do not need a lot of tools. Just one screwdriver, 1.4mm is a good size, tweezers, and hand levers to remove the hands plus hand pusher tools to replace them. Of course if you want to do a full cleaning and restoration more is needed. But to get it apart and diagnose, only minimal tools.
    • I do indeed have some programming and electronics know-how. 3 decades writing code for a living, and playing with microcontrollers as a hobby. 🙂 It helps with my actual living of being a voice actor because I can maintain my own equipment- no one around to replace the caps or the tube in an obscure botique mic that isn't made or supported any longer. Also saves money maintaining and cleaning my own interfaces and mixers when they develop problems in the faders and such. That said... I do have a question that, I'm sure, will betray my ignorance about certain areas that I have yet to fill in. I understand a "WW" lathe is a "Webster Whitcomb", but from what I understand that is a style of lathe and not a brand, correct? If someone would be willing to clarify and maybe expand on the terminology, it would be helpful so I can better understand the advice being given and know what I need to look into to further my knowledge. For example, a Sherline mill would appear to be either a separate piece of gear or an attachment/expansion to their smaller lathe. When you say you have a WW lathe and a sherline mill, can you say exactly what devices you have? Thank you! (I just realized I have a few Raspberry Pis and some Arduinos of various form factors around here I could probably put to good use in a scenario like you describe above).
