Hi All,
I finally received the parts to complete my PUW 1461, and I’m glad to say it’s up and running.  It is fully wound and kept aside for 24 hours after which I will wind it fully again and then rest with the Timegrapher. Before I do that, I wanted to ask if anyone here knows the lift angle for this calibre? I can’t find it online and I’m trying to avoid doing that manual exercise of figuring it out if someone here already knows that the precise LA is.
Thanks as always!
Sia
Seriously I would learn how to visualise the amplitude, once learnt and practiced a few times it can be performed in just one minute.
I think Old Hippy is rubbing off on you Rich 😂
Tom
10 hours ago, caseback said:
I believe it is 55 degrees.
Yes I too found those but they are not the correct movement. I will go with 55 for now, and then when I come back later to reservice this watch more perfectly I’ll try and figure out the LA myself as @Neverenoughwatchesrightfully suggested .
thank you everyone, as always!
Edited by SiZi
Tom
Lol thats not a bad thing though. I think its good to learn from all the pros, after all they do or did this for a living.
And yes I know what you meant. Sometimes I like to keep it short and sweet...to the point, and other times I can ramble on and on, and on and on and..........🤣
Does your phone camera have a (super) slow motion video feature? Makes it very easy to see the true amplitude (and then adjust LA on the timegrapher). No need to draw on the balance wheel or wind to exactly 180° amplitude.
Definitely not a bad thing, maybe even meant as a compliment
Tom
Tom
For sure Tom for sure, I wonder how OH would have coped with me as his apprentice ? Or a more accurate question,  how long he would have put up with me ? 😂
I make great cups of tea 😂
Yes, that I could do. So do I halve the total arc to determine altitude?
So for example this is the PUW fully wound. I am seeing an approx amplitude of 217.5. At this amplitude the lift angle is about 41.
PUW 1461 amplitude
but here’s a Pobeda / Slava / Zim 2602 that I tried the same with. I am seeing an amplitude of 197, but this shows the lift angle to be 32 (which sounds off, no?). So I don’t know if I’m doing this right.
Pobeda 2602 amplitude
Thanks for helping, as always!
1 hour ago, AndyGSi said:
You should wind the movement until you get 180deg of oscillation.
You then change the lift angle on your timegrapher until it matches the 180Deg Amplitude.
I have tried this too and the results are the same about 32-34 degrees lift angle on the Pobeda/slava/zim 2602. See videos below, first one shows the marks matching up when wound to 180 amplitude, and the second one shows the movement at full wind for cross check (I see about 210 amp which was matching the Timegrapher at 32 LA when fully wound).
Am I measuring LA correctly? If yes, isn’t that a very low LA?
wind to 180 video:
full wind video:
Edited by SiZi
1 minute ago, AndyGSi said:
Normally you'd watch the amplitude from the top.
Are you saying that mark on the balance is 180Deg for the other mark when at rest?
Yes I made a mark on the main plate and a mark on the balance wheel exactly 180 degree away from the main plate mark, then I slowly wound till the dot on the balance wheel and main plate overlapped as you can see in the video.
PUW 1461 amplitude
This is why the 180° amplitude marks on the balance wheel and plate work so much better.
This is easy to do when there are 2 or 4 spokes in the wheel. To be the most accurate, have the balance in beat, mark the wheel edge at one spoke and the plate/bridge at the opposite spoke. Wind the movement until both marks align, then set tg lift angle to have the amplitude read 180°. For marking up I use ink and a fine oiler or for fun luminous paint.
yes in this case it was easier because it has 4 spikes so I could easily mark the opposite side as you have suggested. I still get the same reading. Just to double check, I wound up fully and took a slo mo video which I then further slowed down using an app, I placed a 360 degree protractor on the screen and tried to mark out precisely the angles. This gave me 360+45=405/2=202.5 amplitude which I then used as my benchmark on the timing machine and adjusted lift angle till I got 202.5 amp reading. It’s suggesting even lower than 32 LA.
I must be doing the tests incorrectly, but I can’t tell how. I feel like I’m doing exactly what the video online and what you are suggesting. I’ll try the same tests with an Omega 620 I restored recently and see what results I get (since the lift angle on that one is well documented). I also have some more Pobeda 2602 movements I am restoring so I’ll check those too.
thanks everyone!
thanks everyone!
Yes try the test on a movement with a known lift angle. A picture of the pallet fork might give us a clue if the LA is correct and a definition as to what LA is.
Some brands have widely varying lift angles, Omega has through its calibres a range from mid 30°s all the way up 70°.  Japanese brands also have some very low LA, I found quite a few Citizen in the low 30°s
A simple definition of lift angle...degrees of balance wheel rotation during one lifting phase of the pallet stones/escape teeth. At the opposite end of the lever...the start to finish engagement of the impulse pin/fork. The event of escapement takes up a portion of the balance swing, which equates to an amount of degrees known as lift angle.
There is another definition....the amount of the impulse pin's movement of rotation from start to end of one escape event...but that basically adds up to the same previous definition. Looking at the shape and width of the fork slot and impulse pin shape and size may give an indication to a lift angle ?
A simpler answer as to ' what is lift angle ? '...Its just a number that we tap into a timegrapher, a criteria ( some information regarding the escapement design that it doesn't know ) that it requires from us so it can calculate and tell us how far a balance swings one way from its rest point. Something that we can already do more accurately just by watching the balance wheel. It's handy to have a timegrapher show us constant change if any but that isn't dependent on knowing the exact lift angle. So in reality knowing lift angle isn't really that important...is it ?....not to me anyway.... because I ain't designing or making a watch.
Edited by Neverenoughwatches
This is an interesting point. For me, personally, I don’t want to get too academic when it comes to amplitude or beat error or lift angles. I really just want to be able to restore vintage watches into healthy functioning timepieces. All this lift angle thinking yesterday got me wondering if I might just take a more manual approach to obscure and less precise movements like the ones I’m working on by just capturing the balance wheel on slo mo and further slow it down on the computer and eye ball the amplitude to know it’s working within a healthy enough range + or - even 10% inaccuracy. Especially considering that even with amplitude there seems to be some debate over what is “acceptable” or not. If and when I restore high end precision pieces I think I will be more particular. But for these practice pieces maybe I’ll eyeball and then test by wearing and if all is good I’ll call it a day 🙂
I am learning so much at present, everything is so new and exciting! And I really appreciate all the help you all provide here!
Your comments are basically the end point I was making. How deep do you want to delve into the mechanics, maths and physics of the escapement ? We're not making watches here...so not that deep, but understanding the basics are definitely needed for testing and correcting common escapement issues. Particularly when it comes to old pocketwatches that have been through the mill of escapement trial and error adjustments. There is some good books on this subject alone.
Lift angle of USSR 2602 movements is 42. What seen on videos/ amplitude readings is correct. The conclusion is that for some reason the timegrapher doesn't calculate amplitude correctly. Who cares? If You know how to see amplitude, then don't mind what timegrapher shows.
Edited by nevenbekriev
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
