ETA 2824-2 Date Disply
Any way to fix dials to movements you can think of and more has been tried Glen. The dial is maybe not original, to the watch. The problem with dial dots, if the adhesive gets for whatever reason, they ease up on holding the dial in place. Attaching feet is a nice permanent solution, if you want to go to the trouble of it. Its a tricky process with risks however you do it. I'm not sure I've seen dials without feet before, but probably. Often they are there and only push on to the movement with dial feet screws. -
By HectorLooi · Posted
Not all dials can be soldered, especially those made of aluminium. The back of the dial is a real mess. I think someone tried soldering before. I think dial dots, or double sided tape would work fine in this case as there is plenty of blank space on the movement. It would have been a problem had there been a day disk and date wheel. -
The GR3257X is the new generic spring. The X on the end signifies it's an Automatic Spring.
By CoastsidePockets · Posted
Thank you both. One clarification please: Of the two mainsprings listed above, which one is the modern bridled version? That is, which one should I buy? Again, thanks for your efforts. This is an invaluable resource.
