I am working on a Hamilton caliber 64A and found a canon pinion configuration that I haven't encountered before.  I rather wasn't expecting the canon pinion to be connected to the center wheel.   Should the contact between the wheel and the canon pinon be lubricated?  If so, with some 9501 or 9504?
2024_1007_204652_002.thumb.JPG.a4154eda1837305b4d322dc03d602d46.JPG2024_1007_204619_001.thumb.JPG.644d4b2e6678611d742b3db3fcfbc490.JPG
It's metal sliding on metal, so I'd also use a grease. I'm not familiar with many Moebius products, but the ones in the know seem to prefer 9504 to 9501. If you have it already, use that.
Reminds me of something you would find in a quartz movement, accutron or a Seiko where the cp is friction fitted to the hub of the center wheel and does press out and wears out heavily if it isn't lubricated at the joint.
Well, I did manage to pull the canon pinon off of the wheel, before realizing that they were pressed together.  I was able to press the wheel back on with my staking set.
I do think that a grease would be appropriate.  I have Moebius 9504.
This kind of cannon pinions are quite common and can be a pain sometimes when it pops off when levering off the hands.
I usually put a small drop of hp1300 in the groove.
HP-1300 or D5 should do the trick. Grease is unnecessary. Remember that for the majority of the movement's life, that connection is designed NOT to slide. FWIW the cannon pinion attached to the minute wheel is found in the ubiquitous ETA 2824/SW-200 movements.
image.thumb.png.6a933b52ba41f0d98cf0d3e09c7108ba.pngimage.png.37cdeb22ac9a658be5e3191780c84e11.png
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
