Hello,
Does the 5 after the UT 6498 mean that this is a 6498-5?
There is a lot of mention of Unitas 6498-1  and 6498-2 that I've discovered on the internet.
I did come upon one website that mentioned more versions of the 6498 and it said that version 5 was a very rare movement but for the life of me I cant find that page again!
Was I dreaming?
What do I have here?
I am not sure that page isn’t gibberish, the difference between the movements they cite dials, seeing movements don’t come with dials unless in a watch and can use any dial made for its subdial orientation it just doesn’t make sense to me at all.
Tom
That page is for sure gibberish. It does not identify the actual differences between the -1 and -2, which is that -1 is 18000bph while -2 is 21600bph.
What does the small text beside the click say?
Also what kind of shock device is on the balance? I wonder if the 5 could be an indicator of a variance there, as in Incabloc vs a Kif trior spring. Other differences in the Unitas model numbers can refer to whether or not the balance has an Etachron regulator.
Edited by mbwatch
balance/shock details
Hard to tell for sure, but the line that goes across the hinge of the spring makes it look like probably a Kif Elastor rather than Inca. This looks like a legit movement for sure.
It was the banking pins that were throwing me but now I've seen your photo with bridge marked Caravelle 16 0A I understand a little more what it is.
You've got a 6496 not a 6486-1 or 6498-2.
The 5 below does indicate something to do with the movement which were originally detailed on the Ranfft website which has now sadly gone.
What I have found from another forum post is as follows.
7: 4th wheel (optional seconds hand) directly across movement from crown ("intended" for crown-at-twelve pendant watches, with the seconds hand at six).
8: 4th wheel (optional seconds hand) ninety degrees clockwise from crown ("intended" for crown-at-three pocket or wrist watches, with the seconds hand at six).
I'm a little confused here as the last number does look like 8? Versus 6?
https://ranfft.org/caliber/10349-Unitas-6498
Then usually those other numbers are references to changes in manufacturing. Conceivably in this case it refers to a Caravelle watch that somehow was changed. Or the most common reason the numbers there is for height on the dial side. For instance I have an image showing that there were three sizes but this is from the  ETA information and this watch has been around for a long time so there'll always be all sorts of interesting variations.
It appears to be the same as what you find on the Bulova watch it's a date code which I believe is  1972
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=CAR_16OA
That's just my typo.
As per my earlier post, the 5 after the 6498 was all detailed on the original Ranfft site but unfortunately that information was never carried over.
Edited by AndyGSi
Oh I had meant on the outer side from the click, which I should have guessed was "unadjusted" if I had zoomed properly. But interesting about the date code
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
