Old Chronograph Hands (Removal)
An interesting thread in the chronometer club forum discussed the problem that is commonly found when removing an old chronograph second recording hand.
One member  mentions this:
"Yes. Older hands are extremely tight. I break one sometimes and if it came off clean, usually put it in the lathe and attach another tube"
I couldn't get a response on that forum so I am hoping I can gain some new knowledge here.
Is there a reference (book, journal article or video) that discusses this approach (in bold)?
Thank you,
Dean
unfortunately they do come off (usually of the pipe)
I have a watchmaker that will not work on the old navitimers anymore as he has too much trouble with the hands. Another way is to undo the watch dial and pull it up using it to force off the hands (put something between the dial and hand first.
I do have a hand puller and lever and i do tend to use the levers but more room for error.
Others will chime in after a while but im always ready to have to repair the hands on the chronos!
Hope that helps (a bit)
Hi Dean, I would recommend using levers as they give you more feel and control.
Do not use presto type hand removers, as there it is virtually impossible to get any feel or control of the process. When they pull, it happens very quickly with a sharp action that is far more likely to fold the second hand or rip it off the pipe. I know, I've done it!
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
    • I only watched the start, but he's out on magnification by a factor of 10. It's 7X to 45X, not 450X
    • It's one of those tools like screwdrivers and tweezers, where it's worth spending more for the quality. And it gets used all the time. At about £20, the 4040 is not expensive for Bergeon.  When putting a watch in dial down, you have to be careful not to catch a sweep second hand, but once secured, life is easy - two hands available to work on the stem.
