Latest Additions
Nige
Hi all, not posted in a while as I have been working away,and hope this post finds you all well. I have two new watches to show you,the first is a nice Lemania ATP from eBay for £28,it had a broken balance and wrong hour hand,luckily I found a new old stock balance and its all running now,the movement is a Tissot 27A with fifteen jewels and unshocked, have fitted a new hand as well, post-849-0-96129000-1445452808_thumb.jpg post-849-0-01669100-1445452947_thumb.jpg . next up a very nice find ,a sekonda strela chronograph.always wanted one of these,and this turned up at a boot sale with broken balance, New one now fitted and all running,but could do with a clean and I've not yet plucked up the courage to start it yet.I have been studying Mark,s videos on servicing chronos but don't feel up to it yet,anyway here are some pictures.post-849-0-75378200-1445454971_thumb.jpgpost-849-0-69991400-1445455163_thumb.jpg
Hi Geo,yes I agree the Sekonda is a nice watch,it is also in very unused condition,I wonder if it got broken when quite new and never repaired.have you serviced many of these column wheel chronograph,s ? and if so any advice would be appreciated.
I've not worked on a Sekonda chronograph, but it will be similar to other column wheel movement. I suggest that you either purchase a book on servicing chronograph so, or read up about them on line before starting. There are a lot of fine adjustments that are easily messed up if you mistake eccentrics for screws.
Have a look at this set of videos Mark produced, it's not the same movement, but will give you a good idea what you will have to do.
    • Thank you everybody for the replies and advices
    • Yesterday evening I was trolling the net ( as we all do)  when I stumbled on this vid. Last month there was a debate on are Chinese tools worth purchasing and I gave my thoughts that being the biggest differences is the materials used to make them and also they are not built to the Swiss fine tolerances. The tool he shows to compare with the Seitz jeweling tool I am sure is Chinese and shows the point I was tring to make.    https://www.youtube.com/watch?v=CIqQcVLgtB0
    • Good afternoon. More than once I've damaged balance staffs because  tight steady pins necessitating force to get the balance cock in place. I assume the steady pins get slightly deformed over the years by over enthusiastic balance cock removal. So now I take the lesser evil of using a smoothing broach on the steady pin holes so I get the feel and control back when fitting the cock. Is this the best option or am I missing a trick? Thanks all.
    • I dont have any personal friends who are watch nerds so I have to share my joy with y'all 🙂  If you saw my other thread I had bought a Elgin Sportsman to start learning on after getting fairly proficient with my practice movement. I ended up stripping out some threads in the main plate and abandoning that project. I was able to clean it and get it running again so I learned a ton.  Next up, a Gruen Precision that I got off ebay. This project took forever and after realizing the balance was no good and buying a donor movement I was able to get it back in working order. I dont have a time grapher yet but I've been wearing it for 2 days and its keeping pretty dang good time!  - Disassembled, cleaned and reassembled / lubed the entire movement.  - Pressed in a new crystal - Replaced the strap - Replaced the crown (the old crown was just destroyed) One thing that really killed me was that I scratched the dial with my hand levers. I was just rushing because I was frustrated (had to take the hands off a few extra times because they weren't flat) lesson learned.    Next up is a Seiko that I also got on ebay. This will be my first automatic, and my first date complication. Super excited and so glad I found this hobby!
    • Well I actually looked more into it and I think the answer is the following: ST36/3600 is not a clone of ETA6497 it is a clone of OP XI which is a derivation of the ETA. And when you look at both they are actually complete clones (the beat, the bridge shapes even the decoration).
