Latest Additions
Nige
Hi all, not posted in a while as I have been working away,and hope this post finds you all well. I have two new watches to show you,the first is a nice Lemania ATP from eBay for £28,it had a broken balance and wrong hour hand,luckily I found a new old stock balance and its all running now,the movement is a Tissot 27A with fifteen jewels and unshocked, have fitted a new hand as well, post-849-0-96129000-1445452808_thumb.jpg post-849-0-01669100-1445452947_thumb.jpg . next up a very nice find ,a sekonda strela chronograph.always wanted one of these,and this turned up at a boot sale with broken balance, New one now fitted and all running,but could do with a clean and I've not yet plucked up the courage to start it yet.I have been studying Mark,s videos on servicing chronos but don't feel up to it yet,anyway here are some pictures.post-849-0-75378200-1445454971_thumb.jpgpost-849-0-69991400-1445455163_thumb.jpg
Hi Geo,yes I agree the Sekonda is a nice watch,it is also in very unused condition,I wonder if it got broken when quite new and never repaired.have you serviced many of these column wheel chronograph,s ? and if so any advice would be appreciated.
I've not worked on a Sekonda chronograph, but it will be similar to other column wheel movement. I suggest that you either purchase a book on servicing chronograph so, or read up about them on line before starting. There are a lot of fine adjustments that are easily messed up if you mistake eccentrics for screws.
Have a look at this set of videos Mark produced, it's not the same movement, but will give you a good idea what you will have to do.
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
    • The case number should be on the back.
    • I agree, I call it a pallet fork for two reasons, it was the name used when I started watch repair both in written documents and on videos and calling it a lever causes confusion as seen.  Plenty of other examples where there's more than one name. What do you call the opposite side of the movement from the dial side?  I've heard you call it the watch makers side.
