Instead of creating a million threads, I figured I'd keep my notes and questions bundled up here.
I'm working on the barrel at the moment, and it appears to have a detached bridle like my 1954 Bulova 10BPAC, but also has an attached bridle.
The detached bridle is also extremely thin, and in fact doesn't even show up on the photo I took. According to the tech sheet:
Quote
The barrel-cover is snapped on over the outside of the barrel-drum. A slip-ring of similar alloy as the mainspring is placed inside the barrel-drum. This allows the use of a dry lubricant which does not deteriorate and remains stable even if the watch is not in use. In case the barrel needs to be cleaned, also replace the slip-ring no. 1000.7221 and slightly relubricate the mainspring with selflubricant 3.03.
So my questions three:
1. Should the slip ring always be replaced as suggested, or can it be cleaned and reused?
2. Is braking grease still used, and if so would it be on the inside or outside of the slip ring?
3. Do I need to go out and buy dry lubricant? I have Lubeta v105 and v106 which are supposed to dry to lubricating films. Might one of those be appropriate?
You realize this goes against the theme of the message board where it likes everything in separate boxes not consolidated.
Then to add to your fragmented discussion I already answered one of the questions elsewhere.
Then the classic problem of when was this watch made and what is the date of your technical documentation?
Then should I answer your questions? Or?
Conveniently I'm not finding it lurking in the computer as I usually try to convert everything to PDFs and I know I've seen this somewhere and that is the Omega documentation of where they no longer use this mainspring of separate components. It's why if you look in the new list parts list that you don't have it's just one part of mainspring as opposed to two separate components.
Then yes I would've posted images somewhere else on the group of how to lubricate a mainspring barrel with automatic. The two lubricants you mention are not suitable for breaking grease so if you don't have breaking grease ill have to go and purchase that.
I can't tell if this is sarcasm, or if I should be making a separate thread for every question. I am open to following the preferred practices if I know what they are 🙂
Yes, I do have braking grease, which is why I was asking whether it should be used on the inside or outside of the slip ring.
If I'm reading your response correctly, you're suggesting I not use the slip ring at all and treat it like any other automatic barrel. That was my first instinct, but before changing the manufacturer's intention I wanted to verify.
It's more of a observation of? Or perhaps it's one of my amusements with the message board for instance in the past you might post a lubrication question something specific. Then it would disappear a particular moderator would move it to lubrication discussion of  lubrication multiple pages where it basically disappeared never be seen again. Even right now if you look at the way the board is set up things are supposed to be a specific folders. So if you rigidly followed the way the message board is set up one watch would get scattered across many folders as it would fall into a whole bunch a categories of each of the folders. But maybe we can slip by with one watch discussion that just happens to have a whole bunch of stuff that should be another folders if the moderator so obsessed.
As I'm currently looking for something else I've snipped out an image for you. Parts list dated 1969. You'll note mainspring barrel components like the barrel and the arbor and there is the mainspring and part 7221 the slip part of the mainspring.
Then I found you a newer parts list 2013 and you will note the slip ring is now gone. Although one of the disturbing things from Omega is when parts are upgraded part numbers do not necessarily reflect the upgrade. So for instance if you go back in time and purchase the exact mainspring in the image up above you would need the slip ring also in the parts list. But if you purchased the exact mainspring in the PDF I'm attaching it's one spring unfortunately same part number.
Then we have the problem of silly material houses like cousins obsessed with parts and not servicing. So when there are busy downloading that 2013 parts list a could've been downloading something titled General information for Calibre 1000, 1001 and 1002. Did you notice how all the pages of the 2013 parts list every single corner has somebody's name and contact information? This means if for instance somebody did have that general instruction And it came from someplace else they would have to carefully remove wherever it came from just because.
416_Omega 1001 NewLR parts list 2013 from cousins.pdf
Thank you for the once again very thorough and informative reply. I'm sure at this point it's academic, but I'm always curious to know best practices.
This then implies that If I'm planning to reuse the old mainspring (which I am), I should also reinstall the slip ring. I will do that and apply braking grease to the inside of the slip ring as if it were the barrel. This makes the most sense to me.
Also, that bit about the center cannon pinion is very helpful. That wasn't in the tech sheet I have (attached) dated 1970.
Omega 1001(1).pdf
Edited by ManSkirtBrew
I think I'm having a confusion here? You would apply the breaking grease to the inside of the barrel then the slip ring would go inside. Then the mainspring goes in and it catches on the hook on the slip ring.
I did not see a hook on the slip ring. I will check again tomorrow.
It might not be a hook it might be something like this. But still the mainspring is catching on something on the slip ring because it doesn't have its own outer slipping part like the modern ones. The image below came from some vintage Omega thing I'll have to see if I can find where that has gone to.documentation
A different book has this
That's the thing--mine does have an attached bridle like a modern one. I wonder if someone has replaced it in the past.
I'm at work at the moment, but I'll take some photos when I get home.
That's the problem of not revising part numbers. So yes it's extremely concealable if someone put the slip ring back in and then shove their shiny new mainspring which now has its Attached bridal like it's supposed to have.
Okay, it used to have an attached bridle. When I took the spring out of the basket, I was baffled by the plain end on it. Could I have been wrong this whole time? No; the weld at the bridle failed. At least a new mainspring will have me worrying less about all my questions.
Incidentally, I took a good look at the original slip ring under the microscope, and there are no hooks, bumps, or protrusions. It's just a very thin piece of steel.
In one of Stian's videos, he talks about how it was a plastic slip ring, so it seems this was one of the manufacturing changes John was talking about.
Just a little update. The movement is back together and running nicely after lots of fighting with me.
Tonight was case prep. Wet sanded the crystal with 400 through 1500 grit, ran in on a polishing wheel with red rouge, then finished with automotive headlight polish.
It's my first time working out scratches this deep, and I have to say it was a lot easier than I expected it to be.
Edit to note that what I thought was a tiny blemish I missed in the center is actually an Omega symbol! ENHANCE
  • Like 5
Okay, now I have a question. After installing the dial, I noticed the date wheel wasn't working. It worked without the dial, and I noticed there's this red plastic spacer ring under it.
The thing is, the date ring drags on the inside of the spacer. I checked the ring and it is symmetrical top and bottom--no ridges or rebates or anything.
I checked my disassembly photos, and it was just there stuck to the bottom of the dial when I took it off.
20240520181911273.thumb.jpg.89cbcd29dcb0539431ab1ebe0874babc.jpg20240709210514004.thumb.jpg.615c6c1eb02a0c23c74bf3badcc34c39.jpg20240709210542633.thumb.jpg.88340a8860ba7826c4fa6737f4cbf284.jpg
Have you replaced the date ring or is it still original?
You may have to try taking a bit off the inside of the ring as I think you'll struggle to find a replacement.
Thank you both. I just spoke with the owner and he verified that the watch worked when he put it in a drawer for several years, and the date wasn't working when he took it back out.
If nothing else, I know a guy with a 3D printer.
I would do this. a bit of sandpaper on a rat tail would clear it right up. Its just a dial spacer so not a terribly precise part.
It is fickle for sure I put the spacer ring on the dial being careful to get the notches correct around the dial feet and carefully get the dial feet in the holes. If the dial is not seated correctly it will rub on the date ring.
I decided to have a friend 3d print one. I tried sanding the inside, but it's very thin and flimsy, especially where the dial feet go through, so it was not easy.
Broke out the mic and dusted off my old CAD skills. Fingers crossed!
Okay, we got some good news and bad news.
My friend was able to print something very close. I very carefully cleaned the edges with an X-acto knife (you may notice the blood stain at 7 o'clock) and opened up the dial foot holes with a drill bit held in a pin vise. And what do you know, it worked perfectly.
And now there's a new problem: the center seconds arbor. I can't seem to get the second hand pushed far enough onto the arbor because the pinion springs in when I push the hand onto it. This was the best I could do:
I did a little research and found Stian's 1000 video, where he notes:
Quote
When you press the seconds hand on there's nothing to hold the seconds pinion from being pushed back, unless of course you put on the bridge for the automatic module. Then that bridge will hold it back.
The movement is actually designed to put on the rotor first because the rotor post will actually press against the seconds pinion, but even without the rotor post in that hole the bridge will still hold the seconds pinion in place.
Quote at 21:01 here:
I do have the bridge and post installed. The only thing not installed is the rotor itself, but it fits over the post so it's not holding anything back.
Anyone have suggestions?
Looking at the size of the second hand tube I wouldn't have expected it to go on much further anyway?
To me it looks way to high above the dial.
Edit
Just looking through some old notes and I presume the friction spring is located OK?
Edited by AndyGSi
Same here, but it fouls on the inside of the crystal, so I'm assuming it should be a little deeper.
Looking at Stian's video, it does seem like it should go on a bit further, but his also springs in the same as mine, so maybe not?
image.png.400e97110d6ca1f470f833180fb8bcd6.png image.png.fe3e545e4a1d3ed523884d714e7e7f45.png
Yes, just as in the video, with the retaining spring sitting on the sloped shoulder of the seconds arbor.
Okay, I adjusted the hands a bit and everything seems okay now. It sets a lot more easily than I'd expect, but I'm hoping that's just how this movement is. It's running in now.
5 hours ago, AndyGSi said:
I presume it is the correct seconds pinion and you've not swapped it out for the longer version?
You presume correctly.
Alas, my instinct was correct. The minute hand doesn't move with the time. This watch is going to be the death of me.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
