Josmar Swiss anti magnetic
Hi all,
New to watchmaking but an amateur enthusiast. Got a broken Josmar de Luxe 317C to practice disassembly with movements.
I assumed it would have a caliber number or similar so I could find a guide but not as straightforward unfortunately. So I need help identifying the movement so I can learn more about it.
The movement has GP engraved, as well as 98, Swiss, Unadjusted and One (I) Jewel.
https://ibb.co/LtV14VY
https://ibb.co/C0P0k9J
https://ibb.co/1nLLhv7
https://ibb.co/J2NtFms
Thanks,
Pedro
Hi. Other than Richard’s comment the calibre number  89 ? On the plate. There may be other information on the front plate under the dial if not post us reg size in mm and we can try the best fit books.   Welcome to the forum.
    • That black stuff - I had similar things happen with evaporust!  In that case I understand the evaporust eats the iron oxide away without hurting the metal but it can leave behind a layer of carbon which was in the steel that got oxidised. I spent ages trying to perfect a cleaning regime with various different stages in jars in an ultrasonic bath. In the end I switched to washing all but the balance and pallet fork in IPA and gently brushing it with a small artists brush.  I would estimate that I have found an extra 20º of amplitude doing this! It also takes me no longer than waiting hanging over a tank to move stuff to the next jar If it is really bad then I have used the IPA as a prewash and go through my old routine
    • I thought is FHF. Sounds good to make winding stem by myself but I am not in watchmaking on this level. 😄
    • At a friend's request, I've obtained a key for her long case clock which has been silent for some years. On winding it, the weight only rises a foot or so from the floor - & is not visible above the lower panelled section - before the key meets significant resistance. However it then runs quite happily for a day or so by which time the weight is again on the floor. I haven't had the chance to examine the movement but would be grateful for suggestions as to what might be happening here.
    • Despite having to change up your magnification and get your head into the super micro mech zone, I admit I'm not adverse to buying women's watches. You can finish up working on some good high end movements for a fraction of the price of men's. They also finish off that little black dress number and heels look on Saturday night outs. I would laugh but i have had some very odd Saturday nights out , ok go on then I'll laugh, i just made that up....ahem...😅
