Gremlins wear red sweaters
Working on a ladies Seiko that is testing my patience, full service and had it running sweetly - and put it on my winder rig for a 24 hour test, but found it stopped after an hour. I took it apart and found the ubiquitous red fibre wrapped around the pivot of the escape wheel, removed and the watch is up and running again, victory! ......Then it stops again after about an hour, complete strip and notice some movement on the arbor of the barrel... hammer time.... and the watch is up and running again, victory! ......Then it stops again after about an hour. Another complete strip and clean after checking all the jewels on my new LED light box i notice a slight chip (but probably just an inclusion?), re-jewel anyway .... and the watch is up and running again, victory! ......Then it stops again after about an hour.... Top up swear jar, have an argument with Mrs W. and then watch crap TV for the rest of the day.
But I got to wondering, where do those red fibres come from??? I do not wear red or have any red rags or cleaning cloths etc... conclusion is that watch gremlins wear red sewaters ->
Edited by Waggy
  • Haha 4
  • Waggy changed the title to Gremlins wear red sweaters
    • On eco-drives, I've had to replace the battery, then pull the crown out and leave it like that for a few minuets, then push it back in and it start ups correctly.
    • I'm guessing, but this commercial demag machine maybe produces random magnetic fields to re-randomise  the iron particles. So heres one for you, synthetic rubies are coloured predominantly with chromium oxide . But natural rubies and old synthetic watch rubies were also coloured with iron oxide in higher percentages than chromium oxide. Which gave them a degree of.................🤔
    • I've never had a hairspring distort on me by passing the movement or just the balance in a plastic pot over this demagnetiser. Have you seen how fast a cleaning machine spins to spin-off fluid and that does no harm to a hairspring. I was a little concerned when I first used it, thinking it might be too strong, but I was wrong. It is strong, but it does no damage. I pass the part over the demagnetiser and keep going for about an arms length, so about a metre, to properly demag the part.
    • I don't think you would be able to find spare parts. Your best bet would be to get a new movement from eBay. https://www.ebay.com/itm/256508500506?itmmeta=01HY3M863PSA61GK7B859QCWTE&hash=item3bb9191a1a:g:ubgAAOSwrJJgPP-s&itmprp=enc%3AAQAJAAAA4DxWhpiQiz2ZjKpm3PS%2FHPh4IafsSzMWEobc2q4qQWgPGMZ8kCR8y2PRsm7GE31FjeSDYSWcEyGlrpZEdQyyzOSgsgsaPjbP7dYmK8r49Nh%2BEtSqDDIZ8Tbp3vvX035fFXgcjc1GEH8l%2FOWJ9aTeWNGzeBgUwqyhJ3ZSXji50TQr6rd38Sqwaqsj2oc51UVKqqIKySKTfxVB7X09EXcJsmeYc5GCdVODNkb02q2RsxfSIzpgl9dFCmW1Ih%2BPg2j2NziSELg5AfaHl%2FPU2Zn9fNnoVN1Z1NUAREyh2BCubcWC|tkp%3ABk9SR_bhoPTwYw
    • Here's a thought. Try unscrewing the bezel and the crystal. If you have one of those sticky balls for undoing casebacks, I would give that a try.
