Hi everybody my odissey with my first service continues[emoji18].
After I reassembled my eta 2836 I found that the rate variation change very fast from -10 sec/day till 40 sec/day in the same position. The beat error is ok around 0,4 and the amplitude is 300.
Is normal to have that great variation in rate. Do I have to wait some days to start to regulate the accuracy?
  On 9/29/2015 at 8:33 AM, Mark said:
Did you de-magnetise the movement?
Nope i dont have any demagnetizer.....noob here...do you think it can resolve this inaccuracy?
This is one of the most important tools you require when working on watches. If you have a watch that is magnetised, there is no at her way to sort the problem.
You can get them quite cheaply on eBay. This is the type I used to start with before buying a more sophisticated unit.
http://www.ebay.co.uk/itm/406122-Watch-Tools-Screwdriver-And-Tweezers-Demagnetizer-Repair-Kit-Tool-/271876924632?hash=item3f4d20a4d8
To use it you hold the watch against it then draw it away over a distance of about 450mm before releasing the red button. Occasionally you have to repeat the process.
