New and in need of advise- Orient 46941
Hello Watchmakers,
I am a total noob when it comes to watchmaking and I am totally fascinated with it that I want to dive into it. I am in need of advice, as well as, guidance. I have my grandfather’s Orient 3 Star caliber 46941 that as far as I know has never been serviced. It is not running, even after wearing it a full day. So I understand that there maybe issues with it and will know more once I disassemble it and clean it; but I want to acquire some items in advance, that may help me on reassembly. One of them is a new mainspring. I understand that new parts for this caliber may not be able to be found and that I may have to buy a donor movement to assist me, but I will like to get a new mainspring for it, this will mean I will have to buy a generic Swiss ETA mainspring replacement. My problem is that I can’t find info onto what that generic Swiss ETA mainspring replacement model/part number is for this Orient movement . I can’t even find the maintenance/repair manual for the caliber 46941.
Could someone please provide me with some info, point me to the right direction. I would really appreciate it.
Thank you all for your time.
Gio
    • I've just finished refurbishing a Memostar Alarm with AS 1931 movement (same as 1945 but with date and running at 21600). I was also surprised how many parts are available at Cousins. Like you, I was missing the alarm stem (Cousins stock them) and I needed new crowns. It's a nice simple movement for an alarm, easier to service than a Seiko Bell-Matic. BTW I made a note in my Servicing spreadsheet: "Pull out winding stem before removal".  It may have just been wear on my movement, but I found that the yoke could move out of the clutch if the stem was removed in the normal position (like some ETAs).  You might find this interesting
    • I picked up this alarm watch at a flea market several months ago and recently decided to investigate.  I am not finished, but well on my way. As you can see, there was significant water damage.  Running these parts through my L&R cleaner was not enough to clean them, so I did manual cleaning with one-dip and cotton swab (the dense pointed kind).  The wig-wag was stubborn--the two gears would not release from the plate.  I soaked it in Kroil overnight and that did the trick. There was some rust on the balance staff, but not actually on the pivots themselves.  Nevertheless, I chucked it a step-chuck on my lathe and burnished the pivots. The watch is running and I have confirmed that the alarm drive train is functioning.  Since I am missing a stem for the alarm, I have not done the final assemble of the alarm components.  Surprisingly, there are lots of parts available for this movement on Cousins.  I will probably get a couple of stems and maybe some other parts that I deem necessary. The watch is running at weak amplitude (about 190) and shows some poising issues.  I will work on that. The last two pictures are after partial reassembly.
    • Hello and welcome to the forum.    Enjoy
    • Exactly!  It may not really be a joke, but the actual truth.
    • The movement is placed on the base and the centre screw is raised until it contacts and supports the centre pinion, thus stopping the centre pinion from sinking in when the second hand is pressed on.
