I am doing my first repivot and have a question about drill sizing.  I understand that the drill / hole needs to be .02 - .03 larger than the pivot wire that will go into it.  My question is about the following.  I have an arbor that is .50 and an old pivot that is a comfortable 15 in the pivot gauge.  This tells me I should drill it to .17-.18.  The dilemma is finding a drill that exact size.  All the drills I see seem to be either .15 and smaller or .20 and larger except one that I found that turns out to be .1524mm (.006").
Any thoughts out there on this?  Is the recommendation of .02-.03 oversize correct? I guess I could use this .1524 drill and burnish end of the pivot wire down by .01 or .02 to allow it a better fit.
Thanks,
bob
The things are different in reality. And everyone finds his own way in making things to suit his own filling of 'good'.
I will recommend to drill with what drill bit You have. Of course, it must be at least 0.15, as the hole of the bearing is this size. Then, 0.2 will be good, but 0.3 will be problematic to drill in 0.5 and press a pivot in, as the material can easyly crack. Then, when the hole is drilled, You will choose the pivot wire that will be correct for the hole. This usually means that the wire wil not go in, and reducing the diameter (slghtly tapered) will be needed to make it go in tightly.Then I will recommend to use Henkel Loctite 638 'just in case', and wait 1 day or heat the wheel to let loctite harden. In the end, the new pivot should be reduced in diam. to fit the hole and in the same time - to make it centric if the hole was no complitelly centered.
The main problem here is drilling the hole. Usually when drilled to some depth, the drill bit begins to stuck in the hole and rotates harder and harder, then the tip of it breaks and thus ruins all the pinion making it useless. The decision I found is to sharpen the drill bit not symetrically - the 2 cutting edges on the tip to be not equal. Thus the hole is drilled a little bigger than the drill bit diam. The depth of the hole is not needed to be more than 3X hole diam. As You see, I don't use exact sizes of hole or pivot wire and I don't care of it, and don't even have what to measure with...
Now, put this repeater aside for 2-3 years and practice on another movements. You will break probably at least 50 drill bits before get learned how to drill and repivot. Practice is needed... Till then You will learn how to assemble without breaking pivots too.
Edited by nevenbekriev
Thanks,
bob
Hi bob, make the pivot wire to suit the hole not the hole to suit the wire, once fitted the pivot can be burnished down to size. In the case of a balance staff you would want enough on the wire to blend it into the staff cone.
Thanks Neven.  It’s not the repeater. I would not dare.  It is a movement I’ve had in a drawer.  The  repeater is resting. I will buy plenty of extra bits.
Thanks Neverenough.
On 2/26/2024 at 3:47 PM, nevenbekriev said:
OK, have to say that I ment the chinese tungsten carbide bits that I use, which are pritty brittle and easy to break.
I can add to that, i haven't managed to drill any amount of depth with one yet without one chipping or snapping in half. Some of them are extremely brittle, practice make perfect.
I always use tungsten carbide, but 99% of the time I make the drill. Simple spade drill, with slight back-taper along its length. Being free-hand ground, the lips are never exactly the same, so it tends to drill slightly oversize, and that along with the back taper means in the event of a break it just falls out of the hole. They are also less likely to break than spiral drill, in my experience at least. Spiral drills are generally ground with an extremely slight back taper, but in reality when drilling it's like the whole drill is in contact with the hole.
HSS can take quite a bit of misalignment and abuse; but I have never gotten one to drill properly hardened arbors in watches or clocks. Carbide is brittle and fragile, but seems happy drilling hardened and tempered steel.
I usually do it with drill in a pin vice, hand held, but I do put a rod in the tailstock that is a very loose fit in the backside of the pinvice. This keeps it more-or-less lined up.
The main reason I do it like this is for very small diameters I freehand grind the drill, so not only are the lips not exactly equal (I do try to get them equal), the drill isn't really centered on the shank. Holding it in a well aligned tailstock just wouldn't work. The upside is you do have a terrific "feel" of what's going on, and also if the drill suddenly hangs up the pinvice can spin in my fingers hopefully saving the drill.
For diameters over about 0.40mm I can make the drill on my tool grinder, and these end up well centered and can be used like normal drills, either in a live spindle like a drill press or jig borer, or in the tailstock of the lathe.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
