Brass plating restoration
MikeEll
  • 4 weeks later...
If its solid brass then it will polish, what that looks like is the lacquer that has worn away, So you need to strip the case drop in the tank with an ammonia based cleaner to strip the rest of the lacquer away then polish with brasso and clean again then spray lacquer the case again to keep the shine.
4 hours ago, RichardHarris123 said:
Photos please.
I actually posted this under a separate thread.  See here -
3 hours ago, oldhippy said:
Did you lacquer the whole case? If not it will tarnish quite quick.
I haven't done that yet, but good point.
I'm really pleased with the accuracy.  It arrived to me broken and it now keeps perfect time over the course of a week or so.
Edited by MikeEll
I use Mohawk lacquer for brass for all the brass on the torsion clocks I restore
Dell
Edited by Dell
40 minutes ago, MikeEll said:
thanks Dell, I'll add some to my next order.  Where do you buy yours from?
Master finishes.
I forgot to say don’t put it on like normal lacquer, just a dust coat then straight over again with a slightly wetter one but not wet , it looks horrible when first applied but it flows out lovely, try on a bit of polished scrap brass first.
I always preferred to paint the lacquer on, spraying can leave minute bubbles I admit you can hardly see them but you know they are there. Horolacq clear is the one I had and painted on with a paint artist flat brush. I drys very quick.
I found that with most lacquers but not the one I use now, I know some people dip them but I never found that very successful, always ended up with a hard blob .
Dell
