Sharpening Stake Tool Set Punch
By watchweasol · Posted
Hi And welcome to the forum, best watches to train on are cheap but working watches as if they don’t work after your ministrations it’s your fault. Getting broken watches defeats the object. When you work on these and they don’t work afterwards you don’t know whether it’s what you did or was it knackered before you started , so try and make life easier without accumulating junk. Attached a file which is worth going through TZIllustratedGlossary.pdf -
Hi and welcome to the forum. Crack on. I have attached th TZ glossary for you , contains quite a lot of information. Micromat.pdf TZIllustratedGlossary.pdf
