The watch is a front loader.  Crystal is missing and I don't have the original.  I installed a generic crystal but had movement in the movement. Does anyone know what type of crystal I need for this watch?
Is that a flat or curved dial?  Benrus and Hamilton both made GG-W-113 watches using a movement from the ETA 2750 family, but Benrus generally used curved dials while many Hamiltons were flat. Your hands look more like a Benrus model, so I wonder if the dial is a mismatch for the case, which could complicate the fit and seal of the crystal.
I just serviced one of these….
A different board suggested a Stella 24 1/2 was the ideal replacement so I ordered one on the Ebay but received the wrong one so I refurbished the old one.  I was concerned the replacement wouldn’t secure things- I suspect that’s what you’re thinking as well?
Here’s some pics of the original- to me looks like an ordinary hi dome or something but there isn’t a large edge…
Here’s what mine looked like in the case…
This one was inherited by the sister of a deceased USAF pilot so definitely all original Hamilton. From your pic your dial does look like it may be curved…
Edited by rehajm
10 hours ago, markr said:
Movement is marked Hamilton. Dial edge is domed.  I ordered a Stella 24 1/2 crystal.  I'll let you know if it fits.
Your response popped up for me this morning so I went to look for the thread I saw re: the Stella crystals. I didn’t find it but this thread may have some insight on the dial differences and best crystal options…
https://www.watchuseek.com/threads/hamilton-gg-w-113-questions.35726/
No, no chapter ring. I still wonder about the dial. Does it look like a flat dial would better meet the plane of the crystal base and minimize play as in the photo above from rehajm? You can also see the typical Hamilton dial for this model in this walkthrough:
http://www.hamiltonchronicles.com/2015/10/1976-gg-w-113-military-watch.html
If you check the very edge of your curved dial, does it have a thin capital "T" printed above the 12? If so, that would be a big clue because it would signify a Benrus dial that was not original to that case.  There is a lot of mixing and matching going on as people have cannabilized military watches in order to put together things to sell, so you wouldn't be the first trying to sort out a frankenwatch...
Apologies that the Stella didn’t fit - and also that I didn’t take measurements of the old crystal I polished up and re-used…🙁
Based on your first photo I can see wear around the dial where there was clearly something pressing into the finish- like the ledge on a crystal.
Looking closely at the numbers like the zero in 10 and the 4 , these are quite different yours and mine.
Here’s the Benrus ‘Bullit’…
Crystal comes closer to the edge of the hour marker lume. Also no tension ring but a fat lip on the crystal. Maybe look for a deep lip crystal and measure the diameter of the bezel and add a tenth mm or two?
The mixing and matching was very common when these were in the military as well. Could easily be a service watch…
I know this is a late reply, but I just repaired a 1969 Hamilton GG-W-113 and went through the crystal debacle. I bought 4 crystals from ofrei.com. The crystals I purchased are as follows:
Stella 27 1/4 - "LD" low dome wedge ledge
Stella WEC 27 1/4 - High dome wedge ledge
Stella 27 - "LD" low dome wedge ledge
Stella WEC 27 - High dome wedge ledge
I installed the size 27 WEC crystal first but it spun in the case and was just a little to small. I then installed the size 27 1/4 WEC and it worked as intended. No spinning and the height of the dome was good as well. This is for the Hamilton watches with the ONE PIECE CASE design.
Hope this helps,
Edited by yjstevp
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
