Hello everyone, I hope everyone is doing well. I recently got an old citizen new master 22 and managed to run it. The watch was in very bad condition but It is running quite well now and I want to wear it. Sadly, the dial looks very beaten up.
I need advice on what I can do about the dial. Any suggestions would be helpful.
Edited by Reaz
To echo the advice above, it all depends how brave you are, the more experienced on this forum will tell you not to mess with it... a living example of the saying "fools rush in where angels fear to tread".
In reality a lot of the damage resides under the lacquer/varnish coting on the dial, mainly due to water or oil getting under it and causing it to blister/corrode. As this damage is under a clear coating, no matter how much cleaning you do you cannot fix it, and will inevitably do more damage than good.
The limit of what I will do is to blow any loose debris off with an air blower, then dab (never rub) any stubborn marks with rodeco. If the dial is older I may try plain water (no detergent), using a rolling action with a cotton bud (as mentioned by @RichardHarris123 chronoglide has a video showing how to do this). But stay well clear of any text or other printed marks on the dial as the water can lift these before you realise it, been there and got the t-shirt. Newer dials tend to be less robust, older ones are made with the expectation that the watch will be regularly serviced and may include cleaning the dial and are therefore more resilient. However, newer dials are not built to be cleaned (throw away philosophy?) so tend not react well when you try.
Getting the dial repaired by a professional dial restorer is very expensive (often several times more than the watch is worth) so only go down this road for a very expensive watch or one with great sentimental value. Replacement dials tend to be difficult to find and expensive and it's a minefield finding one that is real instead of a straight-out fake or 'aftermarket' one - some sellers are less honest in their descriptions than others. The best option I have found is to look for a donor movement which is being sold with a good quality dial as this can be a fraction of the cost of a stand alone dial (strange but true).
 I rinse the dial in isopropinol or lighter fluid to get rid of any oil, let dry real good, next try rubber eraser, go easy over the prints.
You should see some improvement.
Good luck
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
