I bought these to work on Accutrons because the are non magnetic.  I have many tweezers which I inherited and most are Dumont.  I have two #3s I use daily--a sharp pair and a dull pair.  Sharp ones for delicate work and the dull pair to muscle things around (bending, shoving, etc.).  I love them both...very delicate feel that suits me.  I bought a new pair of Dumont 3C last year and was disappointed with the feel.  Harder to squeeze...I was too accustomed to my old Dumonts.
I bought a cheap pair of Ti tweezers earlier this year.  They are not sharp, have hard feel and just not all that useful.
So, I was skeptical when I purchased the Dumont 5Ti.  Figured they would disappoint.  Well, they did not.  After one full day of use working on an Accutron, I am very happy with them.  Delicate touch, sharp, and light.  I would be happier if they were heavier, but they are Titanium, duh.
So I highly recommend the Dumont 5Ti tweezers.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
