Hi All,
A few years ago I purchased a selection of DPA watch crystals. 250 in boxes of 10 per size from 278mm - 324mm, cost about 80 quid at the time as I recall. I'd now like to purchase the same thing again but cannot find them for love nor money (well, a sensible amount of money).
Does anyone know where I can source such a thing? I went as far as trying to track down the company in India to buy them at source, no dice.
Thanks
Matt
Edited by MattWatch
Spelling
CousinsUK has them in box sets
These guys also do them, but I have never used them:
I think the manufacturer for the DPA crystals is CTS (link HERE), you will need to register with them to get a price catalog and order - I did this a while ago and the registration process dragged on for weeks. They have a lot of brand names under their umbrella. In the past I looked at getting some stuff from them, but CousinsUK prices were about the same, they must buy from them at a huge bulk discount, so I just ordered from Cousins.
Edited by Waggy
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
