Brand new Seiko 6G28 quartz won’t start with new battery
By watchAdventures · Posted
I have a timex urban command (digital watch with indiglo). Are you aware of any dangerous substance or material that I can come in contact with if I disassemble the watch? For example I read that the indigloo is made of luminescent “indium tin oxide” (as reported here https://www.chemeurope.com/en/encyclopedia/Phosphor.html) and that this material can cause irritation to the respiratory tract If inhaled (https://en.wikipedia.org/wiki/Indium_tin_oxide). Any other stuff I should be aware of? Thanks in advance for your answers. -
John, I believe that @zygo has checked the beat rate with timegrapher and has adjusted to exactly 18000, but still the clock goes faster. @zygo, please count the teeth of the wheels and pinions in the train. But the most pobable answer here is: 18000 X 24 / 25 = 17280, which is another well used in various movements beat rate. May be somebody replaced the hairspring and vibrated it for 18000 and wasn't clever enough to count the teeth... -
You are too far away. If can't find somebody to do the job closer and for reasonable price, then post the wheel and the bridge to me and I will do it. -
I get that Tom but their only use is going to be in the event of a forum loss. Other than that a facebook group that can be set aside in case its ever needed.
