8 hours ago, Michael1962 said:
It does not look like a normal capacitor that I am used to. It is slightly bulged around the centre of the plastic outer
If the cap is starting to bulge then its probably on its way out, is it domed on the top as well ?
It's a pair of XY suppression caps so not the same as a failing electrolytic that bulges.
Yeah, that's what I meant. It is not a capacitor that I am used to with a metallic casing with the cross on the end etc. This looks like it has been connected outside of the plastic cylinder and then put together with a filling compound. The is slight bulging around the centre of the plastic cylinder. At least I know it is there. What I will not be sure abut will be how it is all connected should it fail.
I suspect I will be asking questions of Andy again. 👍
Edited by Michael1962
It's just connected as loop in and out so in parallel with the supply to the motor.
25 minutes ago, Michael1962 said:
What is the transparent wire for? I am pretty sure that there is only four wires going into the capacitor.
There should be 5 as your diagram and it should be connected to earth.
One way to see if it's still working OK is to have a radio plugged into the same socket and see if you get interference when you start and stop the motor.
Edit
Just looked back at your photos and it's their just sleeved Green/Yellow as the earth.
Edited by AndyGSi
Clearing the decks so I can get into my clocks. This is a ship that was my mothers. I have had it for probably 20 years and it looked like this.
Now it looks like this. In bits, but you should get the idea.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
