8 hours ago, watchweasol said:
Hi Steven.   Could you post some pictures of the watch, front sides and back.   Thanks
Not sure if I’m doing this right but here it goes
Hi. If the bezel rotates, then it comes off. There is usually a spring under it that keeps it in position and allows you to rotate it. There are tools on the market for removing them. Cousins uk, Aliexpress,  in China, you may be able to pick one up off EBay.      WATCH BEZEL REMOVAL TOOL.   to pop them off safely they apply pressure claws on four sides.  Using a razor blade does work but you need to be careful
That’s what I’m thinking and I have the tools but Spinnsker states it doesn’t come off without taking the movement out. I think they are blowing smoke up my as….  Ok then, thank you for your input.
Hi  The bezel is a separate piece of the case as is the back and crystal. usually when the bezel is removed the crystal stays in . there is a usually a flat spring athough I have had round ones which tension the bezel so it has controlled rotation.  when you rotate the bezel do you feel it click or is is a smooth action.  What tools do you have to facillitate the removal,  If you lookup  bezel / caseback remover on ebay you will get a selection.    Even Rolex bezels remove.   By the pictures your Bezel might be in two parts the knurrled ring and the black ring above it.  Unfortunatley getting exploded diagrams of specific watch cases is along the lines of hens teeth/  just explore ALL options.
Wierd trivia coming up.  Did you know this was actually a thing a couple of  hundred years ago, and was practiced as a medical proceedure.  Apparently medical professions at the time speculated that blowing warm air up drowned victim's jacksees could stimulate the heart and warm the intestines and stomach into recovery. And as such shorelines were equipped with appropriate apparatus ( a long flexible tube ?  KY ? ) to enable this operation. It was accepted that the warm expelled smoke from a pipe could produce enough heat to work and with the simple guidline of " blow do NOT suck " ( ok i made that bit up 😅 ).  Hence " blowing smoke up someone's arse "  showing them an excess of kindness, praise, flattery.  Strange but true.
Yeah. Im just checking to see if there is something I missed since Spinnaker lied to me. I guess they just don’t want me modding the watch
Hi.  As it’s your watch you can do what ever you want to it, whether people approve or disapprove is immaterial. Perhaps Spinnaker removed the movement on his own and was basically passing on the information without any deliberate intent. You are free to do what you want to do without interference, just be careful take it slowly and enjoy the experience,  good luck.
Thanks. Actually I don’t really need to take it off anyway. I’m just removing the insert and having one custom made. I found that if you soak the bezel in some grip solvent over night, the insert will come off.
    • HI everyone Some context: I'm "in love" with old Timex. As someone who has always liked watches, I knew Timex (my first watch and another project) but, in fact, the brand had never really caught my attention. By pure chance I bought, in a set of two others watches, a small m24 that was sold as not working (run and stop), which actually started working by setting the date by manually moving the hands (15 days). This coincidence made me interested in its history, its reputation, simplicity/complexity of the movements and also because some were made in Portugal back in 70’s and 80’s. A few days later I found this beautiful 1975 Viscount, m33 (very low price, almost offered) and this is where I need your help.  It is in very good condition and works well (-20s per day is not a problem for me), and although the day of the week changes correctly, the date is "stuck" on the 10th. I live in a small town that only has one watchmaker and when I purchased this watch (and having read about these movements) I thought that since it was something theoretically "simple" (probably not related to the movement), he would easily solve the problem. I couldn't be more wrong. It was as if I had proposed a pact with the devil. He refused and said he wouldn't touch the watch (although he had serviced several of my watches before - Seikos and old Swiss brands). He suggested I wear the watch like this or trash it. As I mentioned in my presentation to the forum, I have some experience in digital watches, but in manual watches I am a complete beginner. I know how to remove hands, crowns and little else. I've been doing my homework, reading the technical manual and watching a few videos on YouTube. I think I can get to the part of removing the dial without any major problems. I know that in the Date Frame there is a wheel that at the top has a tab that activates the Day Wheel and that at the bottom activates the Date Lever My aim is to try not to ruin anything and  get the date working again. The help I needed (I intend to post photos) is that what should I expect? What are the most common problems that cause this system to get stuck (in this case just the date).   PS -  My secondary objective is to buy a strap at a overpriced value from the watchmaker just to rub it in his face that I managed to get the watch working properly. PS2 - In the photos you can see that before midnight the day of the week is already changing but the day of the month has not changed.   Sorry about the english. Best Regards Vasco
    • What is it from and how did it become bent ? It should bend back - I would heat it whilst bending
    • Ha, same here. I just looked and I've lots of pictures of my cars, be hardly any of me - I have a face better suited for radio. I did find this from about 20+ years ago. I'm the young looking one at the back, under the front nozzle.
    • I have a 6564 with me what is take a same tropic 12 crystal,most likely have the same parameters for the bezel. Do you need the measurement for that?
