Did not know where to post this but here. This is more of a heads up that anything else but if anyone  can help thanks. I have a FHF-96 N movement and after destroying the center wheel (I had it in my pin vise and the pin vise roll off of my table hitting my hardwood floor you can guess the rest) In looking at this https://oldswisswatches.com/watch-parts-branded/standard-st-calibre-movement-and-spare-parts/standard-st-96-n/  I see the part number as 206 so I find one and order it. After I clean it even though it was a NOS part and in it's factory sealed box and after  installing it and then the bridge I could see something is not right the pivot is not coming up far enough into the jewel. So I took it back out and look at it and the old one side by side under my microscope I can now see what the problem is. On the old one the pivot is longer and also the gear is longer which I'm not sure if that matters or not but the pivot is too short.  The box the new one came in dose say 206 so I don't know what's up or what I'm going to do next. Just though I put this out here in case someone ran into this before or may happen to them.
Edited by wudce
 The center wheel  with longer center tube is for  variants of ST96 with date or date/day complications, as date ring takes space which increase the hight of the movement thus longer center tube.
Rgds
Maybe a little off topic, but I find buying a whole used movement from ebay often works out cheaper (in the long run) than buying an individual new part(s), depending on what it is of course. The added advantage of this is that you get the unused parts for free and can maybe use them in the future. On more than one occasion I have needed part X only to find out later in the build that I also need parts Y and Z, luckily the movement I ordered will have these parts and I don't need to return to suppliers to order the additional parts. This is especially attractive to me due to the fact that based where I live it can take two or three weeks to get the part from the supplier to my door, therefore needing one part and then another and then another.... could delay a build months.
There is a risk of course that you may end up with a movement with the part(s) you want missing or damaged, but it's usually worth the gamble in my experience.
Was trying to stay away from buying another movement but may have to. Still is strange what is going on why the data sheet say what it dose yet the part is not the same.😒
It is common for center wheel heights to vary, especially with movements that are used in a variety of different watches.
It's just something that you have to be aware of, and even when ordering a new movement you should know what center wheel height you need.
Best thing to do is to measure the height of the one you are trying to replace, and then verify the new part before ordering.
Cheers!
You say the gear is longer, do you mean the pinion is longer ?   the gear and  center tube is one piece and is called pinion ?  The new one can be replaced with the old, do you have a staking set?
Edited by Nucejoe
You can clearly see from photo the new is not long enough to allow it to come up into the jewel. Not sure what can be done with a staking set but yes I have one.
I'm having a go at making the old wheel flat if bent is the only issue...and the wheel is probably friction fit on the pinion so I suspect Nucejoe's 'the new replaced with the old' is swapping out the bent wheel for the new one on the correct sized pinion.
Edited by rehajm
Just as rehajm expained,
The (  center tube &  pinion  )   is one only piece which is friction fitted onto the gear, and is removable.
 YOU CAN FIT THE LONG TUBE  ONTO THE NEW GEAR.
While you have the long tube removed, you have good access to polish its pinion leaves.
Good luck
 Needless to say, you should measure and make sure both center tube have the same diameter.
Let us see a picture of the new gear center hole after you took its center tube off.
Rgds
The easiest thing to be done is to straighten and true the old original wheel. Of course, if it is just bent, with no broken spokes and no out of round.
The wheels consists of table and pinion. Table is the brass part, pinion is the part made of steel. They are riveted together. Separating them is possible, but then connecting them together is a little problematic - the hole of the table deforms, the riveted part of the pinion must be turned back by rolling on lathe, and in the end - risk of excentric coupling exists.
Been making some head way on trying to  straightening it but it's slow going and I know it will never be 100% right. As far as removing the parts and trying to refit them well that's well outside of my exp level😢
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
