New watch with Miyota 9039 -- A bit concerned with results/want to make sure nothing is wrong
No i know Mike, i just mentioned that as a comparison of casebacks that are super tight. I wouldn't want to make an attempt at modifying one. Good to know that works Mike, you're braver than me, desperation can push your limits 👍 Well hello there Mr. moderator, how does it feel ? Did you get a badge, a uniform and everything. Do i have to salute and call you sir now 😅. I'm a pee taking steward 🤣 -
Before trying wet and dry, you could use polishing compound on the mating surfaces. Wash off. It will remove microscopic amounts of material and smooth the surfaces. -
As a temporary measure we could have a " to trash " email, it takes a of couple minutes to set up . I've just used yahoo , so staying out of the microsoft and google zone. I know that IP addresses can be pulled from just about anywhere by folk clever enough, i prefer not to get too paranoid about this stuff. My daughter was got hacked massively a couple of years ago by a random scammer, he got into all of her accounts except her banking. It was a headache but she fixed it and no real harm done. Waggy's list now has my name but my wife's maiden name and a yahoo email that's it. Safe ish but contactable. Thanks Ross,but please think about how you would make contact if the forum were ever to not be here. -
This is not a "fashion" watch, it was made in 1972. The first time I tried to open it I used a knife blade and hammer to start it, then used the opening tool. I thought it might be stuck with gunk, but cleaned it all up and its just the same. There is no gasket. It's so tight that I cannot hold it down with my thumb whilst trying to prise it with the opening tool. I just have to keep tightening the tool until it pings, which is starting to damage the case. If I leave it as it is, there is a chance of damage to the watch when it is opened. So I feel I need to do something. I just ran a very fine file around the back of the case. I barely removed any metal, and now it fits nicely. Tight, but I can prise it off with the case remover 😀
Cheers both - Wife thinks I'm mad ironing clocks!
