Jules Borel Database Down
2 hours ago, rehajm said:
Still down for me. Interesting...I can load the first search page with the index of brands but not the brands...
Odd,  I can access it from here in the UK. It always shows in my browser (Chrome) as 'Not Secure' . If I try to access the secure version https://www.julesborel.com/, Bitdefender blocks it as suspicious.
5 hours ago, rehajm said:
As I write the Jules Borel database is non-functioning. Is it an occasional blip or is it kaput?
offhand, I would say it's one of the two. what part do you need?
now. rehajm. like santana in the other thread, how does NV make your location list?
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
