What set of mainspring winders should I get first?
By rjenkinsgb · Posted
The setting could have been silver plated? I doubt it would be solid silver. I initially tried various liquids for cleaning, with pretty mediocre results. Eventually I forked out for the gallon-size containers or L&R #111 cleaner and #3 rinse. That stuff, cold, at three to six minutes a stage in the ultrasonic, works superbly; the results are immaculate even on things that are disgustingly bad when they go in. -
That was my gut feeling as indicated in my previous post. The total time in water is 15 minutes which seems too long. I go half that time at room temperature. I go six minutes of cleaning in Elma Red 1:9, less than two minutes of rinsing in battery water, and about two minutes in IPA. Depending on how dirty the movement is I get a fairly good result. For a near-perfect result, I need to pre-clean the parts by brushing them off in a degreaser and then in some IPA.
Yes, the screw seems to be forced in the smaller hole. In such case the screws will not unscrew when drilled with reverse drill bit. You option is to dissolve it. And yes, it is possible to drill a hole in it, then to press tappered broach in and try to unscrew, but it is much harder way.
