Hole shape when using a Seitz jewel-setting-tool reamer?
6 minutes ago, Endeavor said:
That's why I try to get to the source. Once the basic principle is understood, the rest is a logical consequence.
If the theory is correct, than Indeed, the amount of wobble will be the thickness of the shaving = amount of asymmetric.
The logical consequence would be that the to be reamed hole has to have the freedom to float by the amount of asymmetrically and can not be clamped fixed in relation to the reamer.
It's a bit difficult to explain in a non-native language, but I do hope that you get the drift of what I'm trying to explain 😉
Makes total sense to me
It's much more convenient tapping the part in center with the spindle vertical.
That seems to be a lot easier
Here's some pics of my scope. It's a simple setup with a B8 shank that fits the tailstock. Ideally it would be adjustable in one axis, so the cross hair can be brought over to the hole edge, but as long as the hole fits the field of view it works.
What a lovely set up you've got there @nickelsilver
4 hours ago, Endeavor said:
Thanks for that John, now the have the Seitz side of the story, which corresponds with what already has been said.
I was trying to get my head around as to the why the reamer creates the movement, does my theory above makes any sense?
Ah so the holder doesn't attach to the tool its just hand held and the movement from the reamer is just an effect of that design of reamer.
I think i understand now Endeavor. Because the reamer has only one cutting edge the hole is growing in size  asymmetrically around its circumference. So the backside of the reamer has to occupy an increasing asymmetrical space. The amount of cut thickness it takes equals the amount of wobble.
Perhaps we are talking the same? In my virtual brain picture the asymmetrically doesn't increase, it is constant but shifting its position during the rotation, provided you ream with the same downwards pressure, i.e. the thickness of the shaving stays constant. In fact, the asymmetrically decrease towards the cylindrical part of the reamer, where the reamer tapers off.  The "problem" with this type of reamer is that the back-side of the reamer (the non-cutting) leans against the borehole whereas the cutting side digs in, enlarging the hole. One could see it a bit as following an increasing spiral predominantly in the horizontal plane.
Correct. I do agree that there are nicer, perhaps better ways to enlarge a hole. Reaming with a one sided cutting action reamer seems crude, but, in the end of the day, if it works, it works.
I drool over Nickelsilvers machines, but those I may get in my next life 🙂
For now, and to me having solved the initial question, I can ream with these Seitz-reamers, when following the correct procedure, and be confident that I'll end up with a nice, in center and cylindrical hole.
Crude, cheap but effective.
I thank you all for your input ....... I think this was a thoroughly enjoyable and interesting discussion 👍
Edited by Endeavor
Thats exactly how i see it.  I meant the hole is increasing in size but not symmetrical, growing gradually as the cutter makes its way around the circumference of the hole. I think everything has been covered now haha
Beautiful set up there @nickelsilver. What do you use to grind such a fine boring bar, rather than buying them? I'm practicing honing some boring bars at the moment, but need a finer and better grinder
Fine boring bar ? Is that the large chunk of hacked steel with the tiny cutting edge Jon ?
It's a brazed carbide turning tool ground to bore very small holes. I think that one will do less than 0.80mm bores. In the hole is a plug gage showing the hole size.
I use diamond grinding wheels. In my early days (like slightly pre-2000s) used a roughing wheel in a crappy WW lathe, then honed on a copper disc with 3 micron diamond paste. More recently, a proper grinding machine, with diamond wheels, rough and finish. All freehand,  and for tiny things like this, finish the functional faces on another (lathe object) with a really fine, D7, diamond wheel.
    • Since I couldn't slow the machine down enough for my liking, I started off slowly with a higher grit.  I began (very lightly) with 1000 grit paper: https://www.amazon.com/gp/product/B07DTJBND1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Finished with 3000 grit: https://www.amazon.com/gp/product/B07DTFSMT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Afterwards I went on to polish with traditional methods using felt & cotton wheels, with different grades of Dialux. Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
