I have a cheap gold-plated pocket watch (which was a gift from family). I just about broke the knife edge on my threaded bezel/case back opener getting it apart for service. Now I want to put the back on again, and I can't get it to snap together, even with a lever-based watch press. Any suggestions? Thanks.
Depending on the construction of the case it is important that the nylon die of your press is chamfered and touches the case back near the outer edge. By putting pressure on the middle of the back you increase the outer diameter by flatening it and makeing it impossible to snap in.
Could you provide a photo?
Edited by Kalanag
yes definitely pictures would help because there's so many different types of cases that we can't give you advice. Because if we give you advice still probably be for the wrong case in your risk damaging or destroying this one.
I've unfortunately sain something like this before. Notice the wording unfortunately this was really not to be a watch to be serviced. That's why when you went to remove the case back it really didn't want to come off because it wasn't supposed to ever come off again. I'm not seeing the outside of the case back but if you're trying to push in the wrong place it will never go on. I'm going to assume you're pushing in the middle of the case back? You might try pushing only on the outer edges. Often times if you push in the middle of the case back that supposed you pushed on the edges the case back will bend the edges will actually go out and it will never work at all.
I tend to agree with your assessment (this fine French watch with the almost-no-jewel movement was not intended to be opened or serviced.) 😛
I'm using a watch press tool and the die is sized just smaller than the case, definitely pushing only the edges. Don't have a machine shop so I can't turn down the inner lip or anything.
Edited by mhuss
typo
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
