Eta 2824
After reassembling barrel is not working. So i'm trying to wind it, but there is no affect on the barrel and even the crown is pushing back. Barrel is not spinning.
I can't even move the barrel without barrel bridge, but it's not normal.
If my description is clear, please help!
Does it wind with the auto mechanism removed?
Make sure that the crown and ratchet wheels are properly seated and meshed. Also check the keyless - make sure that the clutch is being pushed up onto the winding pinion, and that it is meshing with the crown wheel.
Have a look at Mark's video on servicing the 2824
53 minutes ago, tomh207 said:
I would have a look at the keyless works, the 2824 is very prone to getting itself knotted up. I have seen other comments that a few of the ETA based calibres are like this.
Tom
What do u mean "keyless works"?
Sorry it's not my native language
No worries about the language. The keyless works are the parts generally on the dial side that the crown manipulates. The 2824 movement is particularly sensitive to what position the crown/stem is on removal, this should be done in the time setting position. It is likely that the yoke has displaced from the clutch wheel which is the problem as the winding pinion will not get into the correct position to windup the mainspring.
I hope this is clear, if not please ask again and we will help as much as we can.
Tom
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
