Rectangle And Non-Standard Crystals
Mkay
Hello everyone was just wondering what kind of tools people are using for non standard crystals.
Currently I'm just taking a round crystal and some pilers and just snaping chips of crystals off untill i have the shape im needing. then I'm using my gem faceting machine with a rough diamond wheel to get it in the right shape then a finer diamond wheel to polish the edges so it fits into the watch.  Using a glass cutter is also fine for the more square/rectangle but once u get into a heart shape or oval it gets a little more tricky. This method works fine but its a no fun having crystal fly around as u are chipping it all away. and would take even longer if u try to grind all the extra glass away on the glass grinders.
How are others getting custom crystals made?
Any tips for this raw amateur would be great
thank you
here are some photos of what I'd ended up doing hoping for a more efficient way.
This is used to polish and cut gem stones.
A tool I got from my uncle, this is what he would normally use to cut crystals, but i decided to use the gem faceting machine instead since i already had another assignment that i was working on.
The watch that needed the non standard crystal
Traceing the round crystal and then chipping away (the crystal is still much larder then what it needed to be)
After cutted and fitted.
The other watch that needed the new crystal
Marked and chipped away
Havn't had a chance to finsh this yet since its getting late but ill post more once its done
Just finshed the square watch here the rest of the photos.
Outline. and then chipping away the glass photo can be seen aboved. ended up having to start a new one since i over cut one of the corners.
Over all this took a good bit of time, about 5 broken crystals but being that this was my first time doing custom crystal i think over all it came out well, happy to put my name on this and return it to the customers. with more pratice i hope to do this much quicker. and maybe someone will have some tips or others tools i'll be able to use to make it quicker.
As a side not how much does this type of work normally cost? Currently im charging 45$ CAD retail for this.
Edited by Mkay
Good job, Mkay. The method you used is similar to my friend's who is doing by dozen daily.
The machine he used is as shown in the picture.
You'll need to stock up on different types and shapes of crystals e.g. single-domed, double-domed to meet the needs.
I'm planning to get one for my shop too.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
