Hello ...I have a question regarding my recently aquired omega.
it is a 1977 omega seamaster quartz with cal 1342.
I noticed that the humidity is getting into my watch, and this watch is supposed to be waterproof up to 30 meters...or am i wrong ?  so my questions are do you guys know the part number of the rear cover seal , cristal seal and stem seal....any help would be very welcome.
Waterproof is a misnomer, water resistant is more correct. There is a lot of debate around this, 30m/3atm of water resistance absolutely does not mean that the watch will be fine to dive with to 30m. This level of water resistance is what is common for dress watches and it is not recommended to wash the dishes or shower with it on never mind swim as the dynamic water column pressure will exceed 30m/3atm.
hope this helps
Tom
hope this helps
Tom
Expand
Ok...I understand...but i never dive or swim with my omega, I just noticed some humidity inside my watch lens after a strong rain that somehow hitted my omega directly...I do have a bulova 1969 and tissot that would not be affected by this type of rain...therefore I asked in the forum for the seals...
But thanks for your very good explanation regarding the water resistant....
Expand
It could be dicey in heavy rain or a storm with that WR TBH. With the age of the watch I would definitely look at least to change the caseback gasket and the crown gasket(s). Moisture does not do nice things to watches.
Tom
Tom
Expand
Any idea where can I get them or the part numbers to search them? I have a 1342 omega service parts, but this information does not include such parts...
thanks for your kind help.
  On 3/15/2023 at 5:10 PM, watchweasol said:
When looking for or ordering gaskets for Omegas  you will need the case back number, cousins uk have both the genuine and generic gaskets
Expand
do you have the website of those cousins in the UK ?
thanks for the help
Expand
I believe you will find that most companies will not warranty their watches forever for water resistance. The gaskets with time can disintegrate and usually do. Just because one watch seems like maybe it's not being affected with time The gaskets do have a habit of allowing moisture in and moisture in the watch is very very bad even in small quantities.
Oh and then there is the other little problem. Diving or exposing the watch to water under pressure is different then for instance taking a hot shower with your watch. Or exposing your watch did temperature extremes where it's hot and then cold. Then that's a very bad for getting humidity into the watch. In other words if you heat the watch up the air inside expands and goes out. When the watch cools down it pulls the air back often times bringing humidity or tiny amounts of moisture past the gaskets.
case back number
Expand
For Omega the case back number is the best. But amusingly the case back number doesn't specifically referred to the type of material the case is made of. In other words you look up a case back number and sometimes it could referred to stainless steel or gold or rose gold or gold and stainless steel. Not an issue for gaskets but it could be an issue for a crown or crystal that has a metal ring inside. The other thing that sometimes works if it's a newer watch is the serial number but only if you can find somebody it has Swatch group access otherwise no one else is going to look up the serial number.
Edited by JohnR725
    • Now that I think about it, I can probably just file down the pin carefully to the point where it fits. Is that too much of a hack?
    • You asked for an introduction. I have a Timex Marlin with a cracked crystal. (already said all this--sorry for the repeat in the introduction) I bought a Ling Hui universal crystal puller that was not universal. Can I find a larger puller or is there a different solution. RickG
    • I have a Timex Marlin with a cracked crystal. I purchased a Ling Hui "universal" crystal lift/puller on eBay. I didn't know there was some type of size limit. The jaws are too small to fit around the watch crystal. Returning the item is not worth the hassle and complexity. Are there larger crystal pullers? They made it seem soooo simple. Rick
    • Moebius 9010. A small drop on each end cap jewel (top and bottom)…enough to cover at least half the jewel, but not all the way to the edge. I was conservative.   I like this analogy. And yes, it’s imperfect, because surgeons don’t start with live people. 😂 It’s definitely one of the things I learned with this watch, where I’d fix one issue, but then introduce 1-2 others, often not necessarily getting at the root cause of the “illness.” Well, this watch wasn’t totally destroyed…Unfortunately, I wasn’t able to do enough up-front diagnosis before I started pulling everything apart. This was one major lesson learned to me, but tbh, I don’t think I would have learned it had I not pulled everything apart and seen the interactions of all the different systems (just inside the balance assembly itself!). I have a few other Hamilton 974s that I’ll be able to work on more thoughtfully. I definitely heard your advice, and I think a few others echoed it, but I’m fairly certain I would have introduced more problems by attempting that fix. I don’t have the necessary skill or tools to (1) bend the cock and (2) assess exactly how much it has been bent. I can’t machine a brass plate to attach the cock while bending, I can’t measure the amount of deflection I’ve introduced. And it’s the kind of thing where botching it seemed like it would be irreversible. I’ll attempt to look at the hairspring to see if it’s touching anywhere. The central challenge is that I don’t have a reference point. I don’t have that for end shake or for anything else. I could compare to my ST36, but that seems like an apples-oranges comparison to me (new movement v. 100+ years old). That’s one of the main challenges for me when learning a lot of this stuff – you create reference points yourself! The next thing I was thinking of getting was a JKA Feintaster bench micrometer, tbh. After watching Alex Hamilton measure staffs and pivots, it seemed like it would be a good purchase. They’re just expensive. I’ll need to sell a watch or two first. 🙂  A lathe seems like something where I need to collect more experience before I pick one up. Perhaps you convince me otherwise. In the category of ideas good in theory, but not in practice, I swapped the balance wheel onto the balance cock from my donor, only to discover that the balance cock doesn’t quite fit into the baseplate. The pin on the cock that aligns with the baseplate is either slightly too large or displaced relative to the hole in the baseplate (I suspect the latter). I actually took off the balance wheel and double-checked by trying to screw down the balance cock by itself, just in case there was an alignment issue with the pivot, but no…The picture shows the sizable gap that exists even with the screw for the cock tightened all the way.  This is probably one of those circumstances where I could use a lathe to reduce the diameter of the pin, right @JohnR725? 🙂
