Rado made a lot of watches in this style. Black ceramic dial with diamonds, sapphire glass and bracelets made from black ceramic, tungsten steel and titanium.
Prices on the internet range from $250 to $3000.
I don't know enough about them, so I'd steer clear of them.
I did one of these last year. A ladies quartz. It used a medium range ETA 976.001 movement.
I wouldn't recommend servicing one of these for a beginner. Even replacing the battery can be tricky. The 4 screws on the back hold everything together, once removed, the crystal comes off, the case comes off. The gaskets have to be positioned precisely during reassembly or else they may get damaged and leak.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
