Micro drill bits.
40 minutes ago, RichardHarris123 said:
I had to drill out a broken case pin, luckily I have some micro drill bits but I'm not sure about the quality.  Can anyone recommend a good make and where to buy them?
🤔 been thinking the same Rich. I have some unused vintage drills that go down to 0.1mm, and some cheap crap . Ive been looking at some carbide bits to try.
Just checked Cousins but £54 a set or £6.50 each.  A happy medium would be good.
So i bought some cheap carbide drills after our discussion and they arrived today. Compared to the supposed hss bits i bought a while ago which were rather naff, these are far better. I cant comment on the steel quality but they have very good sharp accurate cutting faces. Ten drills from From 0.1 to 1.0 mm. Up to 0.2mm the edge was sharp , the 0.1mm at the half the size was difficult to see even at x 40 but yet to view through another biological scope i have. Still find it amazing that a cutting face of 5 hundredths of a mm is a thing.
https://www.ebay.co.uk/itm/175352784092?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=wWJ9ztuQRi2&sssrc=2349624&ssuid=tBiLZaCfRb2&var=&widget_ver=artemis&media=COPY
I'm not going to need any for a while so keep me posted on how they perform.
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
