While I use tweezers and a broken oiler to rotate the spring into final position, I found that the notched pegwood works consistently in inserting at least one tab and in keeping the spring under control until I get both tabs in. Real frustration easer.
I have tried two tools. The pegwood with the hole drilled was my go to before i started doing it this way and it was VERY inconsistent but it was the only way i could get these f'ing things in.
The notched pegwood method never worked for me. No idea why but it just never gripped the spring and i'd rotate and the spring would just fly off.
It's such a relief to just be able to do it with tweezers now and not have to worry about. The way i see some very skilled watchmakers to me makes no sense, i try it there way and it sends the jewel flying out of the setting. Most videos i've seen of people demoing how to set these keep the tweezers inside the opening of the spring the entire time.
Once i get that first tab partway in and trap it in with a tweezer i find there's really nowhere for it to go and the other just slides right in. the best thing about this technique is i don't have to have such a light touch. I can just anchor that first set of tweezers onto the bridge and it eliminates any hand shaking.
  • 3 months later...
Figured i'd do the final update as this is now totally finished. I serviced and adjusted an nh36, put in a double domed sapphire so there is now room for the seconds hand and learned how to cut and fit a new stem. Love how it looks with the sapphire and hand winding and hacking is so nice to have.
  • Like 5
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
