Broken Inca Spring / ST3600
Hello Watchmakers
I am just going through the online course from Mark. I'm almost done, however, when inserting the lower ruby stone, one of the legs of the spring broke off. I can't remove the rest of the spring, it seems to be stuck. This is the clone movement of Eta 9498, Seagull ST3600. Is there any method to remove the spring and put a new one?
I am very grateful for any advice
49 minutes ago, manjo said:
Hello Watchmakers
The chaton holder should be removed as the spring comes into position from the outside of the holder. Have a look here at Kalle's explanation.
https://m.youtube.com/watch?v=pJu0mw5kPmI&t=332s
Edited by Neverenoughwatches
Chinese incablocs always had the problem of the shock springs falling off. It might be possible to wiggle the broken spring spring out of its hinge and insert a new one without opening up the jewel chaton.
Slide the spring all the way to one side of the hinge and see if it can be coaxed out of the hinge. Getting a replacement spring might be a problem though.
thank you for the answers. I will try to find spare parts.
Another short question: When I have mounted everything, it is possible that the balance wheel does not move because  the shock rubies are not installed? I can not find the error. Everything works according to the video course except the last step.
The balance should still oscillate without the top ( train side ) shock jewel and cap installed be it a little wobbly. Without the bottom jewels though probably not.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
