Seiko Kinetic
Seiko kinetic 5m42 movement not holding charge, replaced capacitor all went well. Replace back of watch and looked as if it was working well second hand moving 1 second steps. Pressed button on side of watch second hand moved to show charge approx 30 rapid steps then stopped, now second hand just tries to move and if you press button again it just vibrates. Any help. How does this charge indicator work?
Is what you have thought you could have a stuck button?......first, unstuck the button(s) and clean them...on another forum I saw someone with the same problem and These movements are much like mechanical ones in that they should be serviced regularly.
another problem may happen : You may need to be replaced the capacitor and a full movement tune-up if you Watch is used..if your Watch is new, and Under guarantee, bing the Watch to the store where you bought it..that's what I know about this watch
This could be that some metal or dirt has attached to the rotor (sometimes called stepping motor. This is a magnet) and this would cause the symptom you describe. Unfortunately this means removing the wheel to remedy.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
