Anybody print the barrel closer that's floating around the internet?
46 minutes ago, HectorLooi said:
I can't understand why anyone would bother to 3D print this. The Chinese copies are pretty good and cheap.
I must admit i was thinking the same thing, Gert also. I was going to say great minds think alike but then thought more accurately # thats two skilled repairers and erm ? me #
The only thing I can think of is: they have a 3D printer and they don't have a barrel closing tool and they have spare resin they want to use?
BTW - If you were to use a 45 mm radius and use a depth of 1.3mm at the center things ought to be close enough for gov't work...   🙂
8 hours ago, HectorLooi said:
Probably not. Because I already have a barrel closer.
Yes but just think if he had 3-D printer and whatever your printing with resin or filament just think of all the different pretty colors you get have. They could start printing them for your friends and relatives and soon the planet would be covered with barrel closers or calibration cubes. Yes some people of 3-D printers like to print calibration cubes just because they want things to be perfect.
Then of course is not just printing the object somebody took time to design the object.  This think a much time that took then they had the printed out and ideally they should a probably printed more than one and two to verify that they worked which may be in this case they did not.
10 hours ago, JohnR725 said:
Maybe because you don't have a 3-D printer, if you had a 3-D printer would you print one?
yeah pretty much this. He got his 3d resin printer set up finally. he wants to print stuff. he asked me if there's anything he can print for me. This seemed like a good one. It's also just exploring 3d printing tools a bit. I have a few ideas for ones i could model for printing.
Edited by Birbdad
On 11/13/2022 at 9:04 PM, Birbdad said:
he's not sure why but it doesn't appear to have come out the correct size and can't actually close a barrel.
I suppose I have to use a certain degree of interpretation here?
Then regarding the question of why print one when you could purchase one? May be because you already have a 3-D printer and you're curious?
Now what I mean by interpretation? The reference to it doesn't appear to have the right size that's interpretation thing as to what does that mean? On the other hand if you have a 3-D printer becomes quite apparent what that means.
Sizing on 3-D printers is interesting in that it can be calibrated. In other words they have standard objects there are certain size you print the object you measure and then you can adjust your machine will print the exact right size. Typically it's a 20 mm calibration cube. They can make sure everything is size write your filaments flowing at the right rate if you have a filament printer like I do you get all of this dialed in. But typically with filament printers inside holes they end up being slightly smaller but that's fine you can open it with a drill if need be.
Then the other thing of course you do something isn't quite sized right even though you've calibrated you can tell the software that slices the object in other words makes the object ready for the printer to print it slightly bigger which is currently what I'm going to do with the top part as it seems to have an issue.
You notice that there are two 3-D printed barrel closers. The orange one was printed a very very long time ago. The reason I can tell is the first filament I ever purchased for my printer was orange to that would've been a very long time ago. The file came from somebody else who based it on the PDF. Then don't notice it looks nice and shiny and that's because I put it in a lathe and I sanded all the surfaces they look nice and shiny.
So in the orange version the inside whole is quite a bit bigger and the  top part literally falls on there is a lot of clearance basically several millimeters of clearance.
Now what would be in interpretation of a sizing issue well the blue one I printed. Notice how the top part is not down it's been pushed on a little bit but I suspect if I push it down tight it's not coming off and it will be tight. Somebody failed to grasp that items need to have clearance if there is to slide together. So sliding isn't exactly the word I'm using here it requires a little bit of force here in quite a bit more force if you go much farther. Fortunately 3-D printers have a way of sizing things so I'm sizing it just slightly bigger the top part and let's see if it fits better.
Enough for the fun of 3-D printing for the afternoon I changed the lid part sizing from 1 to 1.1 and that made it about the same size as the orange one although the inside hole was still smaller. Then I change the base size to 1.05 which does make it almost the same size as the orange one except of course the whole was much smaller and reasonably sure the inside curvature is still too great don't think it be a good  match probably for a wristwatch barrel advocates to deep but the fun of it I'll take them the work and compare it to the with the one at work and see how they compare.
  • 1 year later...
So does anyone have a working 3D model of this tool..... yes I got a 3D printer for Christmas and I have to find things to use it on so I don't get criticised for wanting yet another toy I don't use 🤣
I decided to design and build my own model, link here, made sure it could handle the slimmer types of barrels that the existing one struggles with.
I printed mine in PETG, but no reason PLA/PLA+ wouldn't work as well.
The FreeCAD parametric files and .stl files are attached below in a zip archive, change the .pdf to .zip after you download to access. or you can take the .stl files from printables web site 🙂
Barrel_Tool_R2.pdf
Edited by Waggy
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
