is this how hairsprings are modified to work?
By watchweasol · Posted
Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement. Thank you. -
Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
Hi murks a picture of the front as well would help, By the size of the plate it was stuck to I would suggest a coin cell, 2030, 2015 all depends on the height of the cell. And the space when the back is fitted. 3 volt. -
We seem to have gone a bit quiet on this ? Do we all agree to ask Mark for some input on this matter, or is no-one really bothered. -
Well it's good to know I haven't wasted my time reading that book! Yeah they make everything look so easy on paper, but I can imagine how slightly too much pressure on a balance wheel could have devastating consequences.
