Hi all - I am working on a Medana watch with MST 434 movement. I can't find much on this particular movement online. I am looking for some background on what the copper piece beside the barrel in the photo is for (on the small bridge). Is this some sort of support/guide for the seconds spindle, to keep it centered in the minute wheel? I did not remove it for cleaning, and am not planning to unless someone tells me otherwise.
Appreciate your time.
Ps - on unrelated note, has anyone worked on the shock settings on these? I think it is called 'xtensa'? Looking at part photos for a similar movement there seems to be an extra part, a ring. I guess I will find out when I get there!
as you didn't remove it is there anything its holding underneath?
I went to the cousins website at the link below and MST comes up with nothing but that doesn't mean we should give up if you search for the movement number and make a wild guess you get the tech sheet that I'm attaching
https://www.cousinsuk.com/document/search?SearchString=434
it looks like it's called the bearing plate.
it's the problem with creative watch manufacturing is we end up with interesting parts. If there's nothing underneath it then it may be because the sweep second coming through that this is the actual bearing for the sweep second and it's a separate plate because it needs to be the end war there were some other reason why it was inconvenient to manufacture the plate. So that major basically stuck removing it or just looking at the other side as to what you're seeing.
2324_MST 433 434 435.pdf
Appreciated. I need to bookmark that search for sure. I was googling MST 434 and not getting a similar result.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
