Diy rotary cleaning machine
Did you try using the #7 winder with the #6 drum? I mix and match arbors/drums all the time.
When you think about it (as a watch addict) and how much you spend on a typical watch, anything less than about $15 is dirt cheap these days. I mean, that might honestly just be the tax you pay on a watch. You can barely even get a used part off of ebay delivered for that much. In fact, $15 seems like about what a new crystal or a used setting lever would cost to have delivered. I think anything under that would essentially be a, "Holy cow, I got this watch for nothing!" scenario.
Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨 -
Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆 -
[Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
