Platform escapement service
Boz
I'm working on an oldish French clock, barrel movement, with a Thevenet platform escapement. I'd guess it is late 19th century so it probably has natural jewels. It's not precious but it is valued by it's owners. The clock has been knocked to the floor. Luckily it was carpeted. Less luckily, the owner had left the winding key in the barrel. The escapement wheel  was bent out of true, but this was easy to rectify. It looks like the balance took the brunt of the impact as the lower cap jewel was smashed and the lip of the bezel setting was torn. I made a replacement setting using a pressed in jewel:
The difficulty come with assessment of the condition of the remaining jewels. I've examined them closely with my old microscope and took some photos through the eyepiece with my phone. I'm not familiar with how much damage or wear and tear is acceptable. Whilst I'd be able to  replace them with pressed in jewels in brass chatons, I'm not equipped at present to deal with rubbed in jewels, nor do I have a source of them. So my multifaceted question is this: would you replace these jewels, and if so, with what and from where would you source it?
Upper escapement jewel:1606944962_Upperescapementjewel.thumb.JPG.20b1f4840dd7ecca35ad5457c22e4740.JPG
Upper balance cap jewel. A bit chipped at the edge but nicely polished in the middle
Upper balance jewel. Looks smooth in its centre bore but the edge of the hole shows chipping
Lower pallet fork pivot jewel. Bit rough around the hole
Upper pallet fork jewel cracked and chipped
1975384650_Upperpalletforkjewel.thumb.JPG.37fc8c976c21cc8a0ce9a5f37e8daf81.JPGLower balance pivot jewel, looks pretty good
Upper pallet fork jewel, cracked.
Lower escapement jewel, pretty good
Fitted together as is, the clock runs for eight days at a wind. The pivots mostly look in need of a bit of TLC.
Balance upper, looks a bit scored. Also is it normal for these pivots to be cut without a square shoulder?  Isn't the arbor rough looking
Balance lower, seems to have survived the impact
 Escapement pivots seem better. Lower:
Upper needs a polish:
And finally the pallet for pivots. Upper corresponding to the badly cracked jewel:
And lower looking a bit grubby:
All pivots need to be polished and burnished.  The one but last of the bunch of jewel holes need replacing, plus the very last jewel photo. You should be able to buy jewels from a good supplier, have a look on ebay for jewels old stock is always for sale.
Thanks @oldhippy Do you think given the low value it would be acceptable to use pressed jewels as I have the tools to do that, plus I can find that sort of jewel readily?
I would always replace the rubbed in jewels for friction fit, unless it was about restoration or preservation of the timepiece.
As you said, sourcing the jewels will be relatively easy. anything that is of questionable integrity, replace. That's a pretty big job, as it looks like a lot of replacement jewels are needed. The pivots/arbors will burnish and polish up nicely, as there only slight wear on them.
Thanks all your your advice on this. It was good practice using the Jacot tool on less fiddly pivots, and the replacement jewels were simple to fit in pressed in brass mountings. There is no significant change in the appearance of the escapement except the slight change of colour from the old jewels to the new synthetic ones such as the lower jewel in the picture below. The movement works perfectly.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
    • You have answered your own question. You just push the setting lever nipple in or if its the screw in type unscrew it a little. You should always remove any hands and the dial before putting it in your movement holder.
    • Did the old battery leak and damaged the circuit board? Can you post some photos of where the buttons make contact on the circuit board.  Try cleaning the gold fingers on the board with alcohol and also the conductive rubber strips behind the LCD display panel.
