Random thought - why is the minute hand the longer one?
There was glue in the chaton - I took apart the whole balance and soaked everything except the balance wheel in acetone before washing it properly in IPA
So swapping the spring answers why it's so far out. What's the diameter of the existing balance.
I have seen more glued ones like this than I can't stand the sight of. Good clean isn't easy on this and let's hope no glue has run down to the hole jewel chaton.
Need to search for the calib NO. Give it some wind and check the frequency on TG, Greard Preguaux put some 36000 bph in there watches , developed the 36000 beater in colaboration with zodiac and enerhart Fortis & bunch of other guys. If this is a 36000 beater its collectable, the first 36000 beater built, as the higher the beat the more accurate is the piece and Definately a keeper.
