Noob looking for help and advice
Hi,
I wanted to get into horology as a hobby now I have more time and interested in repairing, learning more about the history and engineering and practically what extent I can get to myself. I'm a total noob atm so looking forwards to developing a basic level of skill and understanding.
So thanks in advance for your help!
Tim
Hi Tim  If you are truly interested you could do no better than enrol in Marks  Online courses (information on this site). Mark will take you through from the basics to being competent in repair and handling.  "Watchfix.com" will also take you to Marks courses.   I have attached two documents for you to peruse to give you an idea what its all about.  Hope you find it helpful.     In the mean time find an old pocket watch and get some good screwdrivers, tweezers and a loupe  and have a go,  best get a working one so you know it was ok to start with and should work afterwards.  good luck.   if you need further information just post the questions we are all here to help you suceed.           Cheers
1612608791_ToolsfortheHobbyist (2) (1).pdf TZIllustratedGlossary.pdf
Welcome to the forum Tim! I will often point folks to this web page which offers a really good look at a mechanical watch using some very good animations. If you spend time looking at that you'll learn a LOT. Also, I agree with @watchweasolabout Mark's online courses, they're well done and his level 2 and 3 teach you a lot. Level 1 is also good if you haven't spent the last three months watching every YouTube watch repair guy fix watches - it is really basic.
Hi @watchweasol and @grsnovi
Thank you very much for your comments and advice. I've downloaded the info and looked at the websites. The animations are awesome and mkes it a lot easier to understand whats going on. I'll defo get a course just need to pick the right time.
I did have one question regarding the pocket watch - a new mechanical movement from China I assume would still presumably be good for training on?
Thanks Tim
The Seagull TS36 movement is a good movement to learn on. It's inexpensive and easily available. They ship from the factory without having been lubricated and the hairspring attaches to the balance stud with glue.
    • This digital watch works but the buttons can't seem to be working does anyone know what could be the cause a have know idea?
    • Sorry I'm back again the reason why had   push the jewel out was someone had fitted a wrong one a couldnt get any end  and side shake with the old one ...I'm replacing it.
    • Tah-dah. A mini blow torch to harden it, then quench it and just a lighter held under a brass mainspring barrel that the part sits in to temper, Its important to wipe off any grease from fingerprints with ipa, you might be able to see i missed a bit at the top of the arm. Its a very satisfying process. I now just need to deal with the more difficult repairs, anybody any good at replacing rubbed in jewels ? 🙂
    • No I haven't tried that, I'm just thinking of the most complicated solutions 🤣   Another great idea 👍 All I need to do is hold that little bugger steady while I try and screw it in, without starting to shake, it gets the better of me sometimes but is getting less the more I do 😀  I need to order some bits from Cousins so I decoded to put this to one side until I get a balance screw holder, it may come in useful later on as well. I'm assuming it closes down enough as I don't know the diameter of a balance screw compared to the stud screw, I haven't worked on a movement with balance screws! I'll be getting the cheap one 😆
    • Finally figured out why my hands are so god damn steady. My mum 87 years old , 4 weeks after her stroke and has a macular hole in both eyes, she wiped the floor with me and my lad at a kids stacking chairs toy game. Here she in rehab placing the last chair into position, bloody ' Supergreatgreatgran'  i hope I'm half as fit at her age 🙂
