Eight months ago when I began my watch repairing journey, a relative passed me this unusual gold-plated pendant watch to "have a go". They had worn it daily for decades, till it stopped working (and had long gone out of fashion), and put it in a drawer.  At the time I had no test equipment but it was running slow and didn't run for long either.
Having opened the case to see what the movement was, I put in in a box of "future projects" as I wanted to continue practicing on junk movements.
Now I'm gaining confidence having serviced about forty movements and inexpensive watches, I thought it was time to repair it. This is what I saw on the time-grapher:
The movement looked clean:
Though the finish on the dial side is poor:
During the strip down I noticed some unusual wear to the underside of the centre wheel
I cleaned the movement and reassembled to try and see what was rubbing on the wheel. It was pretty obvious once I checked the play on the barrel:
I asked the owner when it was last serviced. The answer was I don't know, maybe never. I know it was worn daily for twenty or thirty years and dates from the 70s or 80s. I'm amazed that the only sign of wear I found was the top barrel pivot hole. OK time to order parts. I ordered a fresh barrel arbor, barrel bridge, and mainspring. The barrel itself showed no signs of wear or cosmetic damage. I think only the very tip of the teeth were catching the second wheel. It's a shame that I couldn't find a barrel bridge with the same finish. I've not posted pictures of the disassembly as it's a totally straightforward movement.
I cleaned, reassembled, inspected and lubricated (941/9010/HP1300/MolyslipDX/8200) the movement. For cleaning I use naptha and pegwood on the pivot holes,  followed by a three stage cleaning in an ultrasonic bath. I epilame the inca jewels, pallets, and escapement wheel. I use a superfine oiler and check each pivot under my microscope for correct oil levels and cleanliness. On this occasion I ran the watch for a few minutes, then lubricated the tip of three escapement teeth. I'm experimenting with different methods as I also like to remove and oil the exit pallet. I can't find a difference in results with either technique when you get it right. I probably make more errors oiling the ascapement.
Putting it on the timegrapher. 280, 300, 320, 340 degrees, SNOWSTORM!!! Sorry I didn't get a picture but I quickly removed the movement as I could hear it knocking, in order to release the main-spring. I checked the replacement spring and it's measurements were the same as the original however the curve was a little less pronounced. It looked fine, I'd simply replaced it as a matter of good practice. So I cleaned the original and put it in.
Now the timegrapher results show unexpectedly high amplitude, but it's not knocking.
Dial down
Dial up was within a second and two degrees of dial down, and the other vertical positions were similar to the crown right.
On reflection, this watch will spend almost all of it's life crown up, so I readjusted it optimised for that position accepting a greater error dial up and down. After a few hours of running-in the differential between the horizontal and vertical positions has reduced. The various vertical positions all perform similarly so I won't post them all. These are after an hour or so of running:
So I learned a few things on this movement. Firstly I should have picked up on the play in the barrel as I disassembled the watch. Then I've have known as soon as I saw it the cause of the marks on the second wheel. Secondly, I learned that a new spring even of apparrently correct and identical specification may cause knocking. Finally, a lesson I learned early in this journey (taking care of the dial) remains visible on the face of the watch, where I marked it as I opened it all those months ago. You can only see it under a lupe, but it's there on the seconds dial between 15 and 20 seconds.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
