Seiko 4843-8100 movement/dial removal
I need to deep clean my 4843-8100, i got the case back off and the stem out, but the movement won't budge, the few movements I've removed before has all pretty much just fallen out. What am I missing?
You're right about the deep clean!  It could just be wedged by gunk.
The case code on the back should tell you how to open it.  Take a look at the dial. If it's larger than the opening on the back then that's a pretty good sign it's supposed to go out the front.
I cant seem to find a case guide for this movement, but i did find this:
http://akiyose.com/battery-exchange/seiko/grand/grand4843-8050-1.html
It is the earlier A version of the movement, but it looks similar.
unfortunatly it does not show how to remove dial and movement, but it looks like he did it through the back.
i also found this
https://seikoserviceusa.com/uploads/datasheets/4823A.pdf
If i am not mistaken its the king quartz version.
It looks like this is the ring holding the movement:
It probably predates the case type being put on the back, which Seiko started doing in 1978.  They used to list each case number in the casing guide book, but you'd have to find one new enough for your watch to be in it but not so new they case number index is gone.  So probably not going to happen.
The one in the first link must have come out the back.  The dial looks no larger, or maybe even smaller, than the movement spacer ring.  And on the photos looking into the empty case, you can clearly see the diameter is smaller on the front.  Which is typical Seiko construction for a watch like this.
I think that ring is just gunked into place.  The probably fits around the movement, and might have a flange the fits between the movement and the dial.
Figured it out, The ring was supposed to be "un screwed", but it was sort of rusted shut. I proceeded with some "mild persuasion" and now its out. Now i just have to figure out how to get the ring lose so that i can take an angle grinder to it... Suspect the dial have to come of from the movement.
Edited by jpg
    • Drilling is going to be difficult, firstly because the drill bits are so thin and brittle, expect to break a few. The second issue is access to the 'hole', as the other lug will be in the way, meaning that you will have to drill at a slight angle, putting a bending stress on the drill bit and with the slightest drop in concentration .... and back to my first point. I would be tempted to grind them flat with a Dremel type tool or small jewelers file, and then put a center punch in the center of the bit to be drilled so the drill bit doesn't skip around and break... but expect this to be slow and frustrating work. By the time you have done 4 of these you'll be an expert and can come back and tell us all the best way to do it if you go down this route. However, I would seriously consider What @watchweasol said and drill from the outside-in, this will ensure straight holes without having to work around the other lugs. It may be worthwhile making yourself a simple paper template so you can be sure to match the position of each hole before drilling. In the end you will be left with 4 holes on the outside of the lugs, but many cases are made this way and unless you are looking for it you probably won't notice or realise that it's not the way the watch was meant to be in the first place.
    • What works for me (waiting for the villagers to assemble with torches and pitchforks) is to put a liberal (in watch terms) spot of 9010 on one of the pins of the pin pallet, this seems to improve amplitude and beat error.
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
