With a new watch on it's way
With a new watch on it's way to me I thought I would try and find a technical drawing for Tissot Cal 791 it's swiss made right so I thought it would be easy to find one Ha ha think again Tiny I can't find one is there a special place to go to find drawings ?
483462505_161e9af8-59d0-4179-a124-a7d4c287d4fd.jpg.91b92e96baa616aea54fac8aebd29165.jpg
483462505_bf81e44d-a578-4124-a83f-129cd892212f.thumb.jpg.5f400c3c482ea523ea7d3964003323ff.jpg
So I have to shout out to anyone that can help me please
Hiya T.  Did you get the jewels sorted on the Seiko ?
No not yet
I think it came from the second Movement I had on my bench. I can't see any missing jewel holes
My mainspring winder has arrived for the Seiko today so I'm going to wind my barrel tomorrow
Hi @Tiny
Remember to always look around the family your movement comes from where you don't come up trumps if you just use your specific movement reference.
Your 791 is a manual wind no seconds but a 781 is in the same family with a second hand; the 794 an automatic with date. Differences of course but the same basics.
Then Cousins is good for docs: https://www.cousinsuk.com/document/search?SearchString=Tissot. Note 781, 794 etc.
Or google tissot 794 pdf
You get the gist. Hopefully this will get to what you need.
Usually in watch repair unless there's something special about it there probably isn't a technical manual the most you'll ever get is a parts list. Usually the watch companies feel anything that looks reasonably simple that a watchmaker should do it and doesn't need a step-by-step guide. Sometimes the watch companies might have a consolidated guide of several watches but usually they have to have complications of some sort. But it also depends upon the manufacture
Then there are websites like this a online parts listing. If you're lucky they might even still have the part in it can be purchased. But if you're unlucky you can also click on the part numbers and anything get a list of all the watches that use that same part. Often times parts will be used in multiple of watches and he might do a fine those if you can't find your watch in other words if you need apart it really helps to know what cross references to.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=TIS_791
Then next site is interesting it has pictures because often times people don't give us pictures of their watch. It's hard to help people with answers to questions if they don't get pictures you don't did give us pictures that was good. It also gives some technical knowledge like this is part of a much larger family. If there was a service manual but I doubt that there was one often times it would be the base caliber would be the manual your book for and somewhere that might be supplemental on may be. But this one is simple enough I doubt there was a service guide the most you'd ever get would be a parts list if You are lucky.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Tissot_791
Yes excellent advice from “Watchmaker”  & John caliburs develop over time so although they change there are always similarities.. Seiko caliburs being a good example. Over time with experience referring to service manuals only comes into play with a complication.
Edited by clockboy
    • There is a tool to straighten this, but it will cost you 50x this wheel.
    • The devil's creation. They peeled off very easily, yeah no not recommended.
    • You have a very low chance of straightening this, it should be made of hardened steel, which is very brittle. Maybe you could ask for a refund from the place where you bought it? If you go ahead and try to straighten it and it breaks then nobody will refund you.
    • I had purchased this wheel online but the upper pivot is a little bit bent how can a straight it?
    • I've hit this snag a few times and my solution is to hand wind, don't be tempted to crimp in the spring so that it catches the smaller arbor - nothing but misery lies down that road. A new spring is a reasonable solution if you don't mind the wait - given my location this can be more than 2 weeks and postage is often several times the cost of the part so not very practical. Perhaps another brand of winder may not have this issue, but after the pain of buying the Bergeon generic partial set I couldn't face the cost of a second different set. I did purchase a Chinese set when I was starting out, and lucky enough to get a set with steel arbors (most are brass), but they are caliber specific so unless you happen to be working of that specific caliber they are pretty much useless 99% of the time.
