removing back from helvetia
hey guys
Been trying to get into the movement on this now for a few days. Yes i am using the corerect tools. but with no luck it is solid no movement at all. I have just taken it out of a shallow bowl of oil.(just covering the back) that it has been in for 4 days and still not a thing. No movement.  Tried razor blades around the join and absolutely nothing.
Any suggestions gratefully received.
Dont wanna start using heat.
cheers
gary
1 hour ago, Kalanag said:
The shape of the case makes it difficult to hold it firmly without damage. There you have to find a solution first!
I would put a temporary strap on it and then put the watch in a good solid watch vice like this. Not expesive. Just be careful to look out for the spring bars breaking out of the lugs or the bar holes becoming damaged if it is so tight. Or a hard timber insert to fit tight  between the lugs. If the lugs weren't  so thick and part of the cushion case i wouldnt have tried this.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
