Watch Repair As A Second Career ?
I have had a few issues with my Orient Automatic crystal and bezel. The bezel came off with a case knife and I haven't been able to refit it. Doing a bit of research on here, I think that it is an arrangement where the crystal is snapped over a lip on the caseback and then the bezel is installed over the top like a tension ring. I have managed to crack the crystal trying various attempts to press it onto the case. Measuring the crystal with Vernier calipers, I think it is a Sternkreuz XS 314.171 but I can't correspond that to the reference/ case number on the caseback. I also measured the outer diameter of the lip on the case that it may fit over and this is 30.5mm, which is actually 0.7mm bigger than the static inner diameter. Is it likely that the crystal can be expanded enough to snap over that? The inner diameter of the bezel/ tension ring is 32.2mm which works with 31.4+0.7 = 32.1mm Does this sound correct? What method should I use to snap the crystal and then bezel into place? I have a cheap case back press with nylon dies but I managed to break the old one with this method.
York is nice, Scarborough 🤔 Bridlington 🤔🤔. Brid has a good carboot every thursday till 12 o'clock -
Ah nice! I work around York, Scarborough and Bridlington most days. Really nice area. Much better than up 'ere 🤣
I state Yorkshire because nobody has any idea where Hull is. Welcome Greg, i tend to only answer my wife when she says something watch realated to me, like " will you come off that bloody forum " . Strangely enough she is also a member of our group, i think that is only to make sure I'm behaving . -
Rothwell, I state Leeds because people know where it is.
