So after my booboo and ordering the wrong size mainspring winder I thought I would pass the time being creative and not sat infront of TV waiting for the post man to deliver my goods.
so I've been on my woodworking lathe making these pens
Edited by Tiny
photo lol
  • Like 5
  • Tiny changed the title to While I'm waiting
Outstanding work on those pens Tiny. I don't know anything about pens, but I know a left handed #6 winder is the right choice for a Seiko 7019 MS 😉
Nice Tiny 👍. I used to turn about 20 years ago. I still have my old coronet elf lathe. And a load of tools. I may return to it one day.  I used a solution called pegg to seal the stabilise the timber and candle wax to seal the end of blanks.
all the pen blanks are all stabilized I paint my timber with gloss paint or wax it's just there to slow down the drying
👍anything to stop them cracking. It was called peg  poly ethylene glycol if memory serves. It displaced the water content for the peg solution. I used to turn custom  newel posts for stair cases and large bowls. Have a go at banksia nuts theyre great fun. The skew chisel was a real beeatch when it bit and threw.
Im trying to remember tha name of the brilliant multichuck i had for my lathe. I always wanted a myford lathe but didnt have the room or the money at the time. Might revisit the hobby one day. Really nice work on the pens T 👍
Edited by Neverenoughwatches
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
